Problems with AFPD on new PC
I recently built a new PC specifically to run AFPD with High Performance.
I have an ASUS P5N-D mobo with an Nvidia Chipset, Intel Quad-Core Q6600 processor, 4Gb Corsair Dual-Channel memory, XFX Nvidia Gforce 9800GTX+ PCIe video card with 512Mb ram, and a 1Tb WD SATA HD. I have a Thermaltake 650W power supply. I installed XP Pro 64bit OS and everything is running great. I was able to install AFPD and the 1.11 patch. I have all 5 Addons, but I tried to install TrueScale Addon 3, first, and it did not Autorun like the AFPD CD did. I specifically installed the 1.11 patch because I knew it was compatible with Addons 3-5. Is there something that I am missing? |
RE: Problems with AFPD on new PC
I have been running AFPD, with the 1.11 patch, and all the Addons 1-5, on my old P4 machine, without any errors but just slow performance.
Hi Rich,
Your installation sequence should always be main disks.....addons (in number order).....patch. If you have applied the latest patch before the addons, it might cause some problems and you might need to do a complete uninstall and reinstall. If any addon disk does not autorun, it could be a bug with the installer. In this case, just browse the disk content and double click on setup.exe |
Mike - I tried Uninstalling AFPD and ReInstalling as you suggested. First the Main Program and then each Addon, 1-5. Finally, I installed the 1.11 Patch. As soon as I go to Calibrate, all the bars go crazy. I tried Uninstalling and ReInstalling just the Main program, with No Addons. Same problem. I am using the same JR8103 and same USB cable that I am using on my old 1.8 Ghz P4 machine with 768Mb Ram and Nvidia 7600 PCI card.
Did you install the latest video card driver for the 9800GTX? Did you get any error message from AFPD? Did you do a proper controller setup and channel assignment?
Pls post your tm.log file which you can find in the following directory C:\Program Files\IPACS\AeroFly Professional Deluxe You may open the file with a text editor like word or notepad. Just copy and paste the entire content into your post. Thx |
I will post that file when I get home.
I always install the latest graphics card drivers when I buy a new graphics card. I was wondering if Vista 64bit would be a better choice than XP Pro 64bit. It does not matter to me which OS I use as long as my Hardware and Apps still work. I built this PC to improve the performance of AFPD and also to run WinTV as a PVR. I have a WinTV-HVR-1800 PCI-e x 1 card. |
Regarding his Aerofly Pro Deluxe flight sim, there is a Main Program, 5 Addons, and a patch that you have to install, after the Addons are installed. I started by installing the Main Program and then the Patch. When I launched the program, I had to configure the Controls so the Control Surfaces were going in the correct direction. Once I did that, I had to Calibrate the Tx. I have a JR8103 which I have used with AFPD before, without a problem. When I got to the Calibration Screen, everything looked normal and I moved all the Sticks, Switches, and Knobs. When I clicked on OK, all the bars, for each channel, started going crazy. I moved each Stick, Switch, and Knob, and as I did, the bar for each channel became Stable. When I was done, I was able to fly. I installed each of the 5 Addons, one at a time, and each time, the program was Stable. I finished by installing the Patch, as requested.
In a Windowed Mode, I was seeing Frame Rates as high as 1500. The Biplane I was flying flew like a Rocket. I had to slow down the Throttle. I then changed the Resolution from Windowed, to 1900x1080 60Hz. The Frame Rate dropped to 600 and everything worked fine. The only problem I found was that as I worked with AFPD, my Sony Bravia 46" HDTV would suddenly go Blank, display the Bravia logo, and then return the display again. It did this Randomly, and even with AFPD shut down, and the USB cable disconnected, it did it, on occasion, while we were working with WinTV. It had never done this before, while using the Cable Box or the DVD player. At first, I thought it was the Graphics Card, changing Graphics Modes, but the HDTV goes blank for sometimes 30 seconds. It seems that when I drag the Mouse around, the image reappears sooner, but I turned off the Screen Saver and the display still randomly blanked out. Aside from the occasional reset of the HDTV display, the program worked fine. Why is it that I cannot change the position of the Sun or switch from Blue Sky to Overcast? Those features seem to be Greyed Out, no matter what scenery I choose |
Mike - Here is the tm.log file
tm: Library Version 4.4, Copyright (C) 1999-2007, IPACS tm: http://www.ipacs.de tmsystem: init random with 2087538651 tmsystem: cpu type=(nlogical=1) (nphysical=4) (no hyper-threading) tmsystem: cpu=2400 Mhz tmsystem: memory=(physical=4094MB, avail=2998MB) (virtual=2047MB, avail=1861MB) tmsystem: operating system=Microsoft Windows Server2003 family, Version 5.2 Service Pack 2 (Build 3790) Service Pack: Service Pack 2 (Build 3790) loading font v2 texture/fontuni.tff=(2048x2048) (h=16) (nc=65536) (split=1) ok tmgl: loading mouse texture/mouse.tmt=ok tmprogram: AeroFly Professional Deluxe Version 1.11.07.21, Copyright (C) 1998-2008 IPACS loading configfile config/main.mcf=ok loading player configfile config/player1.mcf=ok loading player configfile config/player2.mcf=ok openal: register sound sound/beep.wav=(0, rd=100.00) ok openal: register sound sound/balloon.wav=(1, rd=100.00) ok openal: register sound sound/crash.wav=(2, rd=100.00) ok openal: register sound sound/splash.wav=(3, rd=100.00) ok openal: register sound sound/glider.wav=(4, rd=2.00) ok openal: register sound sound/glider2.wav=(5, rd=2.00) ok openal: register sound sound/glider.wav=(already registered)(6, rd=5.00) ok openal: register sound sound/glider2.wav=(already registered)(7, rd=5.00) ok openal: register sound sound/glider.wav=(already registered)(8, rd=2.00) ok openal: register sound sound/glider2.wav=(already registered)(9, rd=2.00) ok openal: register sound sound/glider.wav=(already registered)(10, rd=5.00) ok openal: register sound sound/glider2.wav=(already registered)(11, rd=5.00) ok afdesign: init ok directinput: init=ok tmsystem: current monitor frequency=60 init window=(window=1920x1080) (screen=1920x1080) (32bpp) (60Hz) (fullscreen) openal: init (default=Generic Hardware) (0:Generic Hardware) (1:Generic Software) (using device = Generic Software) (version=1.1) (1.1) (Generic Hardware) (Generic Software) ok init pixelformat=ok gl: vendor=NVIDIA Corporation, renderer=GeForce 9800 GTX/9800 GTX+/PCI/SSE2, version=3.0.0, opengl version=3.0 (viewport=8192x8192) (texturesize=8192) (stencil=8) gl extensions=GL_ARB_color_buffer_float GL_ARB_depth_buffer_float GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_draw_instanced GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_framebuffer_object GL_ARB_geometry_shader4 GL_ARB_imaging GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_shadow GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_transpose_matrix GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_bindable_uniform GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXTX_framebuffer_mixed_formats GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_texture_shared_exponent GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_blend_square GL_NV_copy_depth_to_color GL_NV_depth_buffer_float GL_NV_conditional_render GL_NV_depth_clamp GL_NV_explicit_multisample GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4 GL_NV_gpu_program4 GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_coverage GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control wgl extensions=WGL_ARB_buffer_region WGL_ARB_extensions_string WGL_ARB_make_current_read WGL_ARB_multisample WGL_ARB_pbuffer WGL_ARB_pixel_format WGL_ARB_pixel_format_float WGL_ARB_render_texture WGL_ATI_pixel_format_float WGL_ARB_create_context WGL_EXT_extensions_string WGL_EXT_framebuffer_sRGB WGL_EXT_pixel_format_packed_float WGL_EXT_swap_control WGL_NV_float_buffer WGL_NV_multisample_coverage WGL_NV_render_depth_texture WGL_NV_render_texture_rectangle gl: extensions=(multitexture) (framebuffer) (separate color) (anisotropic filter of 16.00) (compressed texture) (cubemaps) (shader objects) wgl: extensions=(wglpixelformat) (swapcontrol) (multisample) gl: reducing max texture size from 8192 to 2048 tmsystem: fullscreen modes=(rj-640x480x16x60) (rj-640x480x32x60) (rj-720x480x16x60) (800x600x16x60) (1024x768x16x60) (1280x720x16x60) (1280x1024x16x60) (1600x900x16x60) (1920x1080x16x60) (rj-720x480x32x60) (rj-1440x480x16x60) (1920x1080x16x24) (rj-1440x480x32x60) tmsystem: opengl samples buffers=4 tmsystem: current monitor frequency=60 init window=(window=1920x1080) (screen=1920x1080) (32bpp) (60Hz) (fullscreen) directinput: searching joysticks=none (1::) (1::) (1:programobject:) framebuffer object created (512, 512) framebuffer object created (256, 256) tminput: searching for input devices...(3) tmsystem: searching usb interface (0) 0=radiointerface tmsystem: searching usb interface (1) 1=unable to open interface device tmsystem: searching usb interface (0) 1=unable to open joystick device tmsystem: searching usb interface (1) 1=unable to open joystick device tmsystem: searching dummy usb interface (0) 1=unable to open interface device tmsystem: searching dummy usb interface (0) 1=unable to open joystick device tminput: checking for joystick 0=fail tminput: 1 devices found sim: loading scenery scenery/hahnweide.geo... sim: 1 objects 0 dynobjects sim: start position (3ds) multi pano 1 sim: start position (3ds) multi pano 2 sim: start position (3ds) multi pano 3 sim: start position (3ds) multi pano 4 sim: start position (3ds) multi pano 5 sim: start position (3ds) multi pano 6 sim: start position (3ds) multi pano 7 sim: start position (3ds) multi pano 8 sim: start position (3ds) multi pano 9 sim: start position (3ds) multi pano 10 sim: start position (3ds) multi pano 11 sim: start position (3ds) multi pano 12 sim: start position (3ds) multi pano 13 sim: start position (3ds) multi pano 14 sim: start position (3ds) multi pano 15 sim: load texture grid 8x8 (pano=0) (compress=1) named hahnweide/hahnweide=(3.750x4.500) (8x8) (12x6) sim: sphere 3ds params(0)=0.0000 0.4330 -116.8800 sim: photo pos(0)=-0.1380 0.0120 2.2500 sim: load texture grid 8x8 (pano=1) (compress=1) named hahnweide/hahnweide_tower=(3.750x4.500) (8x8) (12x6) sim: sphere 3ds params(1)=-0.2900 -0.4500 160.0790 sim: photo pos(1)=54.2230 26.9660 11.9610 sim: load texture grid 8x8 (pano=2) (compress=1) named hahnweide/hahnweide_bahn=(3.750x4.500) (8x8) (12x6) sim: sphere 3ds params(2)=0.4700 0.1300 -132.9600 sim: photo pos(2)=-495.9630 263.1890 2.5500 sim: loading ground object scenery/hahnweide/hahnweide.obj=ok sim: loading time=14319177 mus sim: 3 photo scenes tmcollision: 63639 triangles using 8145792 bytes tmcollision: omin=(-4748.6,-2882.9,-74.2) omax=(2626.3,3577.1,439.9) octmin=(10.0,10.0,10.0) tmcollision: otnodes=1567 otendnodes=784 otdepth=26 otlistareas=1045018 tmcollision: otnmaxareas=369 otnavgareas=111 otnminsize=(7.202,6.309,8.032) tmcollision: otareas=87621 mem=8496276 tmcollision: 1567 octrees, using 238184 bytes tmcollision: total mem=8734460 bytes tmcollision: time=0.27s tmcolldynamic: no dynamic objects or triangles sim: loading aircraft 1 christeneagle... tmdairfoil: loading naca0015 ok tmdairfoil: loading flat ok tmdairfoil: loading naca0009 ok openal: register sound sound/g15-3000.wav=(12, rd=4.63) ok openal: register sound sound/g15-5000.wav=(13, rd=4.63) ok openal: register sound sound/g15-10000.wav=(14, rd=4.63) ok generating shadow 0=radius=2.35 bbmin=(-1.41 -1.41 -0.51) bbmax=(1.41 1.41 0.29) sim: creating blurr=Propeller loading input device calibration config/radio0.tmc=ok tmmusic: off tmsystem: calibrating radio deviations= 0 3 6 9 -16 25 (timer=8982) -36 4) 88 (C87DDB48) license: tml file 'afpd-a033.tml' = A033 0000 0000 0000 'AeroFly Professional Deluxe AddOn 3' 'A033-378224B7.lic' (activated=1) license: tml file 'afpd-a034.tml' = A034 0000 0000 0000 'AeroFly Professional Deluxe AddOn 4' 'A034-378224B7.lic' (activated=1) license: tml file 'afpd-a035.tml' = A035 0000 0000 0000 'AeroFly Professional Deluxe AddOn 5' 'A035-378224B7.lic' (activated=1) openal: loading sound/beep.wav= ok 0 22050.00 openal: loading sound/balloon.wav= ok 1 22050.00 openal: loading sound/crash.wav= ok 2 22050.00 openal: loading sound/splash.wav= ok 3 22050.00 openal: loading sound/glider.wav= ok 4 22050.00 openal: loading sound/glider2.wav= ok 5 22050.00 openal: loading sound/glider.wav= ok 6 22050.00 openal: loading sound/glider2.wav= ok 7 22050.00 openal: loading sound/glider.wav= ok 8 22050.00 openal: loading sound/glider2.wav= ok 9 22050.00 openal: loading sound/glider.wav= ok 10 22050.00 openal: loading sound/glider2.wav= ok 11 22050.00 openal: loading sound/g15-3000.wav= ok 12 22050.00 openal: loading sound/g15-5000.wav= ok 13 22050.00 openal: loading sound/g15-10000.wav= ok 14 22050.00 sim: switching to simulation mode... tmdynamics: simulation started sim: aircraft=(9.00,4.50,0.93), viewer=(0.01,0.14,2.25) sim: 2226 memory blocks using 18897716 bytes saving configfile config/main.mcf=ok saving player configfile config/player1.mcf=ok tmdynamics: simulation stopped tmdairfoil: loading naca2314 ok openal: register sound sound/ga0.wav=(12, rd=33.55) ok openal: register sound sound/ga2.wav=(13, rd=33.55) ok openal: register sound sound/ga2.wav=(already registered)(14, rd=33.55) ok generating shadow 0=radius=8.98 bbmin=(-5.26 -5.26 -1.50) bbmax=(5.26 5.26 1.16) sim: creating blurr=Propeller openal: loading sound/ga0.wav= ok 12 22050.00 openal: loading sound/ga2.wav= ok 13 22050.00 openal: loading sound/ga2.wav= ok 14 22050.00 sim: switching to simulation mode... tmdynamics: simulation started sim: aircraft=(-147.00,-129.50,0.30), viewer=(0.01,0.14,2.25) sim: 2494 memory blocks using 38992640 bytes saving configfile config/main.mcf=ok saving player configfile config/player1.mcf=ok tmdynamics: simulation stopped sim: loading scenery scenery/hammelburg.geo... sim: 1 objects 0 dynobjects sim: start position 1 sim: start position 2 sim: start position 3 sim: start position 4 sim: start position 5 sim: shadowcolor=0.0000 0.0500 0.0700 0.6200 sim: load texture grid 8x8 (pano=0) (compress=1) named hammelburg/hammelburg=(3.750x4.500) (8x8) (12x6) sim: sphere 3ds params(0)=-0.3550 -0.4950 -174.4000 sim: loading ground object scenery/hammelburg/hammelburg.obj=ok sim: loading time=3401839 mus sim: 1 photo scenes tmcollision: 9544 triangles using 1221632 bytes tmcollision: omin=(-5417.2,-5416.6,-153.0) omax=(5067.7,5416.9,164.3) octmin=(10.0,10.0,10.0) tmcollision: otnodes=317 otendnodes=159 otdepth=21 otlistareas=184584 tmcollision: otnmaxareas=199 otnavgareas=88 otnminsize=(10.239,5.290,317.309) tmcollision: otareas=14073 mem=1277924 tmcollision: 317 octrees, using 48184 bytes tmcollision: total mem=1326108 bytes tmcollision: time=0.05s tmcolldynamic: no dynamic objects or triangles sim: switching to simulation mode... tmdynamics: simulation started sim: aircraft=(4.50,-12.50,1.52), viewer=(0.00,0.00,1.70) sim: 1280 memory blocks using 30304788 bytes saving configfile config/main.mcf=ok saving player configfile config/player1.mcf=ok tmdynamics: simulation stopped sim: switching to simulation mode... tmdynamics: simulation started sim: aircraft=(4.50,-12.50,1.52), viewer=(0.00,0.00,1.70) sim: 1280 memory blocks using 30304788 bytes saving configfile config/main.mcf=ok saving player configfile config/player1.mcf=ok tmdynamics: simulation stopped openal: shutdown=ok directinput: shutdown saving configfile config/main.mcf=ok saving player configfile config/player1.mcf=ok tmsystem: 156 memory blocks: tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=65536 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=262144 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: acftprevcopy=16384 bytes tmsystem: shutdown, 156 memory blocks left using 7667712 bytes |
I forgot to mention that I had originally installed the latest Nvidia driver when I first set up the PC. I just checked and it is 182.50 for the XP 64bit OS. Now when I installed the program, successfully, as outlined in the previous post, I first installed the Main Program and then the 1.11 patch. I checked to see how the program worked after each Addon was installed. I reinstalled the 1.11 patch after all the Addons were installed.
I did notice, today, that while I was running AFPD, the HDTV went blank again . It does not seem to do that when I am running any other program. My PC case has a 280mm Cooling fan on top and a 120mm Cooling Fan on the Front and Back. |
Rich
I have a similar hardware setup as yours, without the TV. But I am running XP Pro 32 bit. Just possibly, your problem is with XP Pro 64. Remember it was criticised quite heavily for failing to run a number of 32 bit applications. I can't give you references now. I would be interested to know how your memory utilisation is going with a 64 bit system. I estimated that the runtime image in RAM of any 32 bit data or code would have to be doubled when run under a 64 bit system. So my guess(!!!!) was that AFPD run under XP 64 would need twice the RAM it uses under XP 32. As my mother board would support only up to 8 Gb of RAM, I didn't see the advantage of a 64 bit system over a 32 bit system with 4 Gb of RAM. But note, 4 Gb of RAM is reduced to 3.25 Gb of usable RAM under XP Pro 32. I also thought that the speed advantage of the 64 bit OS running on Quad processors would be lost in conversion costs from converting 32 bit code instructions to 64 bit instructions at runtime. All these are my assumptions. It would be great if you could prove or disprove them. The Wildberg multi-pane scenery is fantastic on a large LCD screen. I live in it!!!! Best wishes Mike |
As far as your AFPD setup, it looks like it is running fine. On your question about some greyed out graphics settings e.g clouds, etc, these features are only available for 3D computer-generated sceneries, not photosceneries. Sometimes, blanking can be caused by cabling issues. How long is your cable from the PC to the monitor? Are you using a DVI or VGA cable? Transmitting full hd resolutions (1920x1080 ) using a DVI cable can cause problems. Have you tried using a normal VGA cable, using the VGA input of the monitor?
When I first built this system, the only corner I cut was with the OS. I had a Windows XP Pro 32bit CD from my Dell System. Because of the 1Tb SATA HD, I had to create a Floppy Disk, with a RAID/Mass Storage Device driver, from the ASUS mobo disk. I kept getting a random BSOD referencing the Mass Storage Device driver nvtgs.sys. The only other OS I had was a Microsoft XP Pro 64bit CD. It has been Rock Solid in every other respect.
I have been told, by other IT friends, that there may have been enough differences between the Dell XP Pro 32bit disk and an MS XP Pro 32bit disk that would account for the incompatibility between the Dell disk and my system. I am not sure if I should buy an MS XP Pro 32bit or Vista 64bit disk. The system is running very stable right now. I am using a little over 1Gb of Ram, according to Performance Manager, when AFPD is running. I have been averaging 600fps running at 1900x1080 @ 60Hz, The only glitch is that every 8 minutes or so, the HDTV goes blank, the power light is still on, the Bravia logo displays, and then the display returns. I am not sure if it is the Graphics card that is doing that or the HDTV, however, it only seems to do this when AFPD is running. I did have it happen a couple of times when I was running WinTV. It never happens when I am just watching cable TV. The PC is running DVI to HDMI cable to the TV. The last time I loaded AFPD, last night, I did not experience the display kicking out as often as it did the time before. |
I am using one 6ft USB cable extension and the AFPD cable is connected to it.
I was under the impression that I could only get HD resolutions if I used DVI to HDMI. When I was using my Nvidia 6200 card in my P4 machine, I had to go from DVI to VGA on the TV and I believe the VGA port only supported 1300x??. I called Nvidia support and they told me I needed a 7000 series card or better to get HD quality and use a DVI to HDMI cable. I put an 8400GS PCI card in my P4 and I have been running DVI to HDMI without a problem, for 6 months, at 1900x900 res. |
Rich
Thanks, I might have an answer to my question. AFPD running on your system uses "a little over 1Gb" according to the performance manager. AFPD with everything set on max quality with the Wildberg multi-pane scenery running alone on my system uses just on 400 Mb according to the performance manager. Don't take this as gospel yet; I need to do more tests Best wishes Mike |
Mike - I tried hooking up a DVI to VGA cable but I can only use 1280x1024 res as the Video card sees the HDTV as an Analog device. The display looks much worse than it does with the DVI to HDMI cable.
Mike - Is it possible that since my Desktop res is set to 1600x900 and AFPD is set to 1080i that it is triggering the screen blanking?
Hi Rich, I don't think so. I am not sure what the problem could be but your AFPD setup is perfect.
Thanks very much!! Your timely support of AFPD is a valuable addition to an already abundant array of quality features.
| All times are GMT -8. The time now is 10:11 AM. |
