RCU Forums
-   Ikarus Aerofly flight simulators (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/)
-   -   Set Up Flapperons procedure (https://www.rcuniverse.com/forum/ikarus-aerofly-flight-simulators-337/9766126-set-up-flapperons-procedure.html)
tzirancamaro 05-28-2010 07:37 PM
Could you please advise me with the procedure to set up flapperons to a model airplane in the Aerofly Pro De Luxe for Mac Os X 10.5 and a Futaba 6EX transmitter?
what I want to obtain with the function of the flaperons is that both ailerons move downwards when I flip the switch of channel 6 of my transmitter
I have been trying to make it work, without success
In order to obtain the flapperons to work, first I activated the function FLPR in my transmitter, later I fit function FLTR to 25% with switch of channel 6 activated (up) and to 75% with the same switch deactivated (down)
In the main window of the Aerofly program, menu CONTROL, I have tried assigning to the right aileron to the channel the 1 and left aileron to channel 6
So far, when I active the switch corresponding to the channel 6 on my radio, the ailerons move in opposite sense
I have tried to revert the sense of channel 6 in my transmitter but I do not obtain the result of which both ailerons move simultaneously downwards
Please help me
Thank you
rajul 05-28-2010 07:44 PM
RE: Set Up Flapperons procedure
Check the servo function on your Tx to check your Ch1 and Ch6 servos move as expected with the spoileron or flaperon mixes on and off. In AFPD advanced control panel set Left Aileron and Left Flap to Ch6 and Right Aileron and Right Flap to Ch1.
tzirancamaro 05-31-2010 06:35 PM
Hi,
Thank you for your help, I made the set up as you advise me
Once I made the recommended changes, in my first attempts it didn't work
Later I discovered that it is necessary to calibrate again the transmitter in the AFPD main menu
after to have made any change in the programming screen of the transmitter
once realised this, the AFPD accepted the changes
Now the flaps works great!
Thanks for your support
rajul 05-31-2010 06:37 PM
OK good. One more note: If you are using dual rates in your radio, calibrate at high rates
