Go Back  RCU Forums > RC Airplanes > IMAC
Reload this Page >
correct my info plezzzzzzz
IMAC Discuss IMAC style aerobatics in here
Old 09-19-2003, 12:56 PM
online_qtr
Default correct my info plezzzzzzz
thers asmall misstack in my head ... that my qwestion is..
when i make the mix OK its meaning up elevator (nose up) the eleron coms down like flap
down elevetor (nose down) the eleron go up oposit the flap.
thank you
__________________
MUHANNA
Old 09-24-2003, 07:27 AM
RickP
RickP's Avatar
Default RE: correct my info plezzzzzzz
It is difficult to understand your question, but it sounds like you are wanting to utilize the Spoileron function on the radio? Just set one side to negative an the other positive and you should get the effect you are looking for.
What radio are you using?
RickP
Old 09-24-2003, 10:43 AM
Scott Claboe
My Feedback: (9)
If you are trying to mix the flaps with the elevator,you are right on.The flaps should go down with up elevator(nose up) and up with down elevator(nose down)!This should help with squaring up those sqare loops.Also helps with walls and harriers!!
Old 09-24-2003, 01:21 PM
online_qtr
thank you (Scott Claboe)
i mixed them... but the problem ........ in my head
the --spoileron-- is up elevator down flaperon like that \ /
not like up elevator up flaperon like that \ \
is it right .
thank you
