Need Advice on 50cc Engine Pick!
NY
Hi
I recently bought a Midwest Extra 300XS Kit.
I dont know which engine should i put in it.
Either a Brison 3.2 or DA-50... Or any other recomindations???
I would want to be able to do 3D on it and need some advice.
Appreciate the help!
MN
I am contemplating that exact combo. The Brison guys really love there engines, and the DA guys, well!!! Do you have a drill press for drilling props? I think the brison will come out at a 150 less than the DA.
ID
I have also been connsidering the same engines. The difference in engine cost is $100 then you have the mufflers amd accessories. I think the DA would be a more powerful engine. Does anybody make a "? header" for the Brison to use with a can?
If you had ever dealt with DA and experienced their customer service first hand this would be a no Brainer. Da has bar none the best support of all the engine manufacturers I have ever dealt with. The DA will run smoother, more power. Sure the 4 blot hub means you have to drill the props with a drill press but the prop wont slip the way they do on a single bolt hub.
Shawn
Shawn
My Feedback: (69)
AR
All I know is its due in Dec for the rear carb version. As light as the other light 50s, power we shall see, but if I was a guessing man, I would say it will be pretty good.
