Go Back  RCU Forums > RC Airplanes > IMAC
 IMAC vs Pattern >
IMAC vs Pattern
IMAC Discuss IMAC style aerobatics in here
IMAC vs Pattern
Old 11-07-2008 | 11:39 AM
Default IMAC vs Pattern
Besides the fact that IMAC planes must be built to a scale version of a full scale plane, what are the major differences between flying IMAC and flying pattern?
Thanks in advance for your replies.
Old 11-07-2008 | 12:13 PM
exeter_acres's Avatar
Default RE: IMAC vs Pattern
really that is about it...
There are slightly different manuevers but they are quite similar.
Pattern planes are purpose built RC planes that must be under 11lbs and fit in a 2m by 2m box....
IMAC has no size or weight limit. The planes must be "scale" models of full scale aircraft capable of flying in the aerobatic box....
There are unique rules for each organization, but overall they are quite similar.......
Old 11-07-2008 | 02:12 PM
IMAC does have a weight limit which is the 55lb AMA limit with fuel, not that too many of us are gonna get close to that
Old 11-07-2008 | 09:34 PM
could the pilot have the AMA experimental aircraft waiver?
Old 11-07-2008 | 09:44 PM
Yes...
Old 11-07-2008 | 10:20 PM
vertical grimmace's Avatar
One is just slightly less boring than the other!
Old 11-08-2008 | 07:00 AM
which one?
david
Old 11-08-2008 | 08:05 AM
ORIGINAL: vertical grimmace
which one have you competed in?
Old 11-08-2008 | 09:35 AM
I supposed both could be a bit boring to watch for the average spectator. But, the average spectator probably has absolutely no clue what is actually going on.
I spent the entire summer trying to perfect the Imac basic routine, probably 150 flights, and never got bored, and never was satisfied with my performance. This was just practice, never got around to competing, yet.
Considering there are 5 levels of Imac competition, and every level gets a new routine every year, factoring in different wind conditions every flight, etc., I don't see how it could ever become boring. Unless you are just soooo good that it no longer is a challenge for you. That seems impossible to me.
What got boring to me, was boring holes in the sky. Practicing Imac has given me a purpose and direction to my flying, and from the comments I've gotten from my flying friends, I have benefitted greatly.
I've even gotten 3 of them interested in Imac, and we plan to compete next summer.
Old 11-08-2008 | 11:01 AM
apereira's Avatar
The pattern planes are easier to fly as they are aerodynamically better designs, actually they are designed to be a perfect flying machine, or at least get close to, the IMAC planes being scale down of a real airplane has all the design flaws form their original counterpart, as they need to carry a person, accommodate a predesignated engine, and the flying surfaces are designed to have great performance but while maintaining the pilots ability to move them without mechanical assistance.
The schedules are quite different as they are designed based on the airplanes capabilities to execute them, there are maneuvers that will be very difficult to perform by it's counterpart, and even though both types of airplanes are capable to do whatever maneuver is created, they will not do it as pretty as it will with the corresponding aircraft.
Old 11-08-2008 | 02:20 PM
MHester's Avatar
Ok why not.....just to be specific LOL
They are indeed very similar, but in some cases very different. Besides the planes themselves, the flight is judged a good bit differently.
IMAC is more focused on the execution of the manuever, with very critical dowgrades for things such as wings not level etc. The routines are extremely "busy", as in a lot of movement and tons of snaps.
Pattern is much more "controlled" as far as the actual flight path of the plane. you have a "box" which is 60 degrees to each side of the pilot and 60 drgrees up. Anything outside of that box is severely downgraded....like 2 points for every quarter of the manuever that is outside of the box poles. Also there is a very strict center, as in there is a pole and you better split it...or get severely downgraded. You have to do your entire routine minus take off and landing within this box at a parallel line 150 meters in front of you. In AMA pattern, the take offs and landings are scored as well.
Other than that, a loop is still supposed to be a circle, a roll should be on a rail, you get the idea.
IMAC and pattern planes fly EXTREMELY well. they are designed to take as much load off the pilot as possible. here is where pattern has the edge because inside of that 2 meter box and 11 lb limit your plane must fit, anything goes...and I mean darn near anything. This has lead to some really innovative aerodynamic limit-pushing to get the plane to fly as neutral as possible in all angles of flight, and that includes knife egde. IMAC has to stay "scale", so they are somewhat more limited in that aspect. but some of the newer designs are really testing that
To me modern pattern planes fly better than anything else out there. I like the IMAC stuff too, but since I am a builder and desinger, I get a real kick out of pushing that envelope in search of the perfect plane.
As far as the excitement factor: BOTH are not a spectator sport. It's a participant's sport (or hobby, passtime, addiction, whatever LOL). personally I find 3d to be MUCH more boring than pattern or IMAC. Fun? Absolutely!! But not nearly as challenging as trying to nail that perfect flight in a gusty 30mph crosswind. So if it's boring to you, well, don't bother with it. It's probably just not your thing and that's fine. I will say that in other countries, pattern type contests ge ta LOT more spectators than a regular fly in sort of thing. I think America is just jaded that way. And that's fine too, all that matters is that I enjoy it, and so do my friends, and new people every day.
But to sum up...it's something that if you're interested in at all, you have to DO it, not just watch because you may never "get it" by just watching. it takes a certain personality type to WANT to try and fly a perfect circle dead on center and wind corrected in a strong wind, when everyone else at the field packed up already. if you're not "that guy", just keep on boring holes in the sky and doing whatever is fun to you. but if you ARE that guy, I would greatly stress that you should pick an IMAC or pattern plane, go out and practice, and then just go to a contest. And say hello to the most addicting thing in life......
-Mike
Old 11-09-2008 | 12:12 AM
MTK
ORIGINAL: MHester
-Mike
Jeez Mike, tell us what you really think. LOL
Hey, dudes and dudettes, Mike is on the money here. Indeed, Pattern model design is unlimited within the 2X2 meter box and 5 kilo rules attempting to make a design that performs precision maneuvering nearly effortless. Many are true thoroughbred designs with one goal in mind: PA with as little pilot input as practical
A scale model for IMAC has the full scale counterpart as the main limiting factor in its design. That can be huge handicap. A few years ago when the rules allowed up to a 20% departure from scale, many opted for longer tail moments which immediately resulted in groovier, more precise platforms. Freestyle suffered a bit but precision benefitted greatly
MattK
Old 11-09-2008 | 05:46 PM
I fly both Pattern (recent addiction) and IMAC (old addiction). I have more time flying IMAC but want to do more Pattern.
Both are great.
There has never been a 20% deviation from scale. 10% has been and is the rule since I've been flying IMAC (10+ years).
I haven't flown any of the cutting edge pattern planes- I am flying a ZN Line Supreme with an OS140RX. It is an awesome flying plane. Having said that, my 40% Carden 300 with a ZDZ Super160 flies better (my opinion)- maybe I'm just more use to it. Easier to see, slower, better power to weight (believe it or not), snaps better- everything is just more solid. Maybe if I was flying the "latest design" pattern plane with tricked out electric propulsion or YS 170 I might feel different. Pattern plane definitely flies better than my 35% Extra and smaller planes.
IMAC plane is clearly more of a pain in the rear to deal with when transporting, setting up, tearing down, storage, etc.
To me the main difference, other than the planes, is the sequences. Pattern sequences are simpler- not saying that they are easier to fly- but have more simple elements. There is a greater concentration on the shape and flow of the sequence. IMAC has lots of snaps and complicated manuevers and a new sequence every year. I have lamented that I don't have enough time to learn to fly the sequence as well as I'd like. IMAC also has unknowns in all but the entry level class. That's fun.
Both Pattern and IMAC are great. The two disciplines are close relatives. You can't go wrong with either.
Old 11-10-2008 | 05:48 AM
don't know why but pattern is definitely more popular here, there a 5 times more posts on the pattern forum.
david
Old 11-13-2008 | 06:49 PM
My Feedback: (42)
Hi Dave:
I guess I could be wrong, but I thought there was a time in the mid to late 90's when the fuselage could deviate by 20% from the wingspan, where the wingspan set the % scale for the model. I remember that there were some designs like the 37% Godfrey Extra and and one of the Aeroworks Extra designs that were really stretched to the max. There was a change in % deviation that tightened up the specs, but I don't remember all the specifics anymore. Remember at one time too, there were designs like the Gator Giles And Hanson's Excess (An Extra 300 that pushed the rules to the max)? If I recall correctly, they would not meet today's rules, since something did change to reduce the deviation in the fuselage scale. Was it width or length deviation that changed?
Old 11-15-2008 | 09:53 PM
All of our models have met the 10% rule. Sometimes the builder would shretch the numbers and move the rudder hinge line back and also sometimes get caught but stock they were within the limits just like our current models.
Robert
www.bobflues.com
Old 11-15-2008 | 10:03 PM
My Feedback: (42)
All of whose models?
I'm really asking about how the rule was written roughly 8 to 10 years ago. It has definitely changed, but I'm a little fuzzy on the specifics of exactly how. My recollection seems to be different than Dave's.
Old 11-16-2008 | 09:47 PM
My Feedback: (45)
Having flown both, they are both a lot of fun..I personally prefer pattern, but plan to fly more IMAC next year. The biggest difference I have noticed is how they are judged. IMAC has much busier individual maneuvers, but they dont judge other things...such as center. As long as the maneuvers are in sequence that is fine..they don't truly judge the center of the box as is the case in pattern. I have flown a LOT of 40% planes and while they fly well, they don't touch a purpose built top of the line pattern plane for drawing lines. Part of this is they are shorter coupled..so they do snap and tumble better. You can't go wrong flying either...and both will make you a better pilot,
Arch
Old 11-16-2008 | 10:45 PM
All of our models??, Sorry my name is Robert Godfrey, Son of the late Bob Godfrey and President of Precision Aviation Design. I had worked with my father from the early 80's untill he passed a couple of years ago. I have been designing models from about '95. I did the 10% verification from the late 80's on for all of our models including the present designs. Also I see that I mispelled our websites address its, www.bobflies.com there is a write up on dad on the main page that has some of the history you are talking about. We still produce models here in Florida and I take care or my Mother here also. All of the present production models will fly Pattern or 3D without any C.G. change by design.
Robert
Old 11-16-2008 | 11:43 PM
MTK
ORIGINAL: bobflies
Robert
Interesting...So Bob Goddfrey Models became Precision Aviation Design.
Do you guys make a real pattern capable airframe? If you do, you should advertise in the KFactor. If it's a good flier, many guys will buy it if reasonably priced either as kit or ARFie
MattK
Old 11-16-2008 | 11:50 PM
Jetdesign's Avatar
My Feedback: (8)
Anyone know if the Quique 'somenized' yaks are within the 10% and legal for IMAC?
Old 11-17-2008 | 08:55 AM
There was "Precision built models and kits" and "Precision Aviation Design" but never a Bob Godfrey Models and yes I am planning on designing a pattern plane for Andrew Jesky that will be electric, gas or glow and all wood. Our IMAC models are very capable of drawing straight lines.
Robert
ORIGINAL: bobflies
MattK
[/quote]
Old 11-20-2008 | 05:51 PM
ORIGINAL: NJRCFLYER2
Hi Dave:
I will agree with Dave here...without a doubt, IMAC has never had a 20% rule at all.... It has always been 10%. Whether builders have changed or not, IMAC has not. I have been a member since 1990.
Wayne Matthews
IMAC # 1294
Old 11-20-2008 | 06:12 PM
My Feedback: (42)
The scale rules have changed during that time, but my question is exactly how. It may never have been to 20%, but there were changes. I guess if no one remembers the specifics it doesn't really matter.
Old 11-21-2008 | 02:28 PM
The only rule that I know changed was the stab had to be located to 10% of the vertical stab. That was a TOC rule change in 1998.
I have flown both disciplines. Flew pattern for 20 plus years and IMAC the past few years. Both in my opinion have there pros and cons, but I enjoy both. Go with what you like and go with. I get into more Pattern vs. IMAC debates over nothing. Most of the time, one doesn't know anything about the other. But they think they do.
Rick
