IRC Racing Support The online retailer for many of your r/c products is available to support RCU members. Click here if you need their help or have a question for them. Hosting this forum will be RADICALJ, RC-BOSS, MINDCRIME and REDCATRACING1.
Fuel tank leak around fuel cap fix
Old 06-15-2006, 02:16 PM
bfrunner
Default Fuel tank leak around fuel cap fix
Not really a fix but more of an adjustment.
If your Vulcan is leaking fuel around the fuel cap becuase the O ring in the cap is barely making contact with the mouth of the tank here is a simple solution. There is a small screw on the bottom of the fuel cap, tighten the screw up a little at a time until the fuel cap flips snuggly onto the fuel tank. By doing this you are compressing and spreading the O ring. This also keeps the tank pressurized alot better.
Remember not to over tighten the screw or you will strip the screw hole.
Old 06-15-2006, 10:13 PM
rcworld2000com
Default RE: Fuel tank leak around fuel cap fix
that does not work for mine still leaking tighting does not help
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
