Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > 1/16th, 1/18th, Mini & Micro RC Cars > IRC Racing Support
Reload this Page >
ok mindcrime ill try again ok my two speed is not working
IRC Racing Support The online retailer for many of your r/c products is available to support RCU members. Click here if you need their help or have a question for them. Hosting this forum will be RADICALJ, RC-BOSS, MINDCRIME and REDCATRACING1.
Old 06-16-2006, 02:32 AM
rcworld2000com
Default ok mindcrime ill try again ok my two speed is not working
ok mindcrime
i have tried the tightening the set screw
i have used lock tite
and i have even emailed surport
and i have aksed for help !!
so what do you know that i am not doing or doing wrong
Old 06-16-2006, 09:36 AM
huw4027
Default RE: ok mindcrime ill try again ok my two speed is not working
I am glad to see that you are changing your response and sincerely hope that you will get the support that you need to rectify your problem.
Old 06-16-2006, 10:18 AM
Mindcrime
rcworld, you said you have tightened the set screw....did you try to loosen it at all? there are 2 set screws, one that holds the assm to the shaft, the other one is at an angle. and is the adjustment, it should not be screwed in all the way, it will never shift like that...
as far as emailing support and not getting an answer, I appolagize.....we try to answer all emails, but perhaps we missed yours
let me know if you just tightened the set screw or tried adjusting it.....
Old 06-16-2006, 10:37 AM
rcworld2000com
yes i have tried tighting the set screw i moved it in a little maybe a 1/18 turn at a time then would run buggy again. eventullay the screw stop going in so i then moved it out a few times still no shift.. at atleast one i cant hear i would think i would be able to hear it like others yes?
and the screw i am moving in and out is the second screw the one at angle..
thanks for the help.
Old 06-16-2006, 11:23 AM
Mindcrime
rcworld, moving it out will make it shift sooner....if you try it again and it still won't shift PM me and we will figure it out...thanks
and yes you should be able to hear it shift
Old 06-16-2006, 01:26 PM
rcworld2000com
no shift so i will pm yo u
Old 06-16-2006, 01:35 PM
huw4027
That is how problems are solved, all the best guys. [sm=thumbup.gif]
Old 06-16-2006, 04:27 PM
rcworld2000com
me and mindcrime are working on the problem.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
