Cheetah SE 160 SW latest version and parameters
My Feedback: (18)
Hello,
Can someone tell me the latest version of software for the Jet Central Cheetah SE? In the Info screen it is listed as: SOFT_VERSION:
Also, if you could share your settings for the screens below.
Running Screen - values for each of the below:
LINEAR, HALF or EXPO Thrust
Thank you in advance.
Screenshots would be perfect, as it may be easier than typing it out.
- Max RPM
- Idle RPM
- Accel_Time
- Acceleration Curve
- Decel. Curve
- Speed_LIM
Hello Skunkwurk
The acceleration value may change because atmosferic conditions and fuuel pump wear, the curves are more a preference choice, and also the radio curve setting
The default settings are:
Max RPM: 130,00
Idle RPM: 34,00
Acc_Time: 10
Acc_Curve: 1
Decel_Curve: 1
Half expo
Regards
Max RPM: 130,00
Idle RPM: 34,00
Acc_Time: 10
Acc_Curve: 1
Decel_Curve: 1
Half expo
Regards
My Feedback: (18)
Hello Skunkwurk
Max RPM: 130,00
Idle RPM: 34,00
Acc_Time: 10
Acc_Curve: 1
Decel_Curve: 1
Half expo
Regards
Max RPM: 130,00
Idle RPM: 34,00
Acc_Time: 10
Acc_Curve: 1
Decel_Curve: 1
Half expo
Regards
That is actually why I'm asking. I set my Acc_Time to 10 and it changed automatically to 17. Can you confirm the current & latest software release for this motor?
My Feedback: (18)
Hello Skunkwurk
Max RPM: 130,00
Idle RPM: 34,00
Acc_Time: 10
Acc_Curve: 1
Decel_Curve: 1
Half expo
Regards
Max RPM: 130,00
Idle RPM: 34,00
Acc_Time: 10
Acc_Curve: 1
Decel_Curve: 1
Half expo
Regards
note: just asking for the version #, not the actual code.
My Feedback: (13)
Mines don't really change their values once they get established in the first few runs in the plane. I think the algorithm will slow the turbine down if needed, but wont accelerate it. So only adjusts in one direction.
If you think 17 is too slow, i would reset it to 10 and then do a few runs in the ground to let it adjust again.
Hi Skunkwurk
Last software version is 36-37 as Edgar said
If you can make a download of the last hour and the parameters and send it to [email protected]
I will check the prblem and make the parameter correctios if needed
Regards
Regards
My Feedback: (18)
Hi Skunkwurk
Regards
Regards
