Is it ok to use the HDT with telemetry connected ?
I have 2 160se's that are connected to Jeti telemetry sensors. I would like to run cables in the model so I can use the HDT for adjustments. The power packs are not easily accessible. Is this ok?
thanks |
Hello Bobneal1
It is ok, you can even connect both with a "Y" connector if you need to Regards |
Juan, I have 2 160 SE Cheetahs. I have telemetry s on each for Jeti. I can only see the data for one engine. I have 7 parameters displayed. I have tried each separately and they both work. I can see the "State of each engine in the Jeti box emulator but not individual engine parameters. Do the telemetry adapters each have their own unique id number? James at Esprit says they must each have id numbers to show up individually. I have the two of them connected to an RSAT 3 through a EX 4 telemetry expander.
Thanks, Bob Neal |
Hello Bob
We have a special Jeti telemetry for the second turbine, that telemetry will show as #2 on Jetibox and all sensors Please contact Jose Melendez at //[email protected] for an exchange Regards |
