Jet Central Gear sequencer
I need some help with a Jet Central gear sequencer. I have everything working the way I want but when I select gear up it comes up and the doors sequence correctly
but after a little bit the gear will come back down. But then the strange thing. It will go back up and start over again. it does this about 4 times. when I select gear down everything works just fine. Anybody have any Ideas. I have the fail safe set to 3 bars. |
Hello Bill
It is probably the battery fail safe, it can be adjusted but the minimum is 5.4V Regards |
Juan, that did not help. I think I have a unit that the pressure switch is not working.
I will send you a video of what is happening. thanks |
Juan, I sent a video. Please note that I never touch the Tx after the first time.
thanks |
Bifurcated Tail Pipe
Hello Juan, I am starting a build that will be using the Jet Central Cheetah. My question to you is where can I get a bifurcated tail pipe for it? Would gladly give the necessary measurements, etc. Many thanks and have a good holiday. You can send your response here or to my email address: [email protected] Thanks. Chic
