Smoke on P-60
RE: Smoke on P-60
the turbine while running produces pressure on the 3mm line with very hot bypass air (this line is blocked off with the kerosene start plug use on an SE turbine), the smoke tank has to be of sufficient strength to not explode under the pressure (i used an old powermax can, it has the clunk built into it), although it works, it's not all that great a setup and the Tam smoke system is by far a much better system and a lot more practical.
RE: Smoke on P-60
it's injected into the jet blast, just deep enough to completely vaporize the oil, too deep and it burns rather then vaporizes and you get low smoke, too far out and you get extra fluid down the pipe and it makes a mess.
