Flashing green IO light
My Feedback: (13)
I have a P-60 SE kero start with 15 hours. When I attempted to start the turbine for the third flight today the IO board had a green light flashing. No other lights come on i.e. the amber and red ones and nothing I could think of would cause trhe sequence of green amber red to start. Anyone have any ideas. The battery was freshly charged and I tried the manual option for starting.
RE: Flashing green IO light
when the green is blinking alone and the turbine is not running and all other lights are functional it's an indication of slow down mode from a failed start. what was your RPM reading???
My Feedback: (13)
I'm not sure what is different, but all appears well now. The problem came up when trying to go for the third flight of the day, so I had taken the plane in the shade and charged the battery and flew a couple of other planes. Probably an hour since the previous flight. I fueled up and went to start and only got the flashing green light.
Thanks for your help.
John
John
ORIGINAL: KC36330
The fact you mentioned putting it in the shade says it must be hot where you are and probably the EGT probe was just registering a higher than normal reading preventing the turbine from going into start sequence.
If it happens again plug in your GSU and check the EGT reading, if it this problem starts to occur more frequent, check that the EGT probe is reading what should be the temp that day whether it is in your workshop or at the field. It may need calibrating or even replacing.
My Feedback: (13)
OK
It happened today that I got only a flashing green light on the I/O board before the first start attempt. When I checked with the GSU the temp reading flashed back and forth with 'xxx' and 'xEx. I would assume this is a temperature error code. How do I fix?
John
John
My Feedback: (13)
OK,
Thanks for tha advise. The cable between the turbine and the ECU was bad. The light no longer flashes, but I won't be able to check until tomorrow if the turbine lights off as this was my cable for link to the GSU. I'll pick up another at Florida Jets.
FL
I bought all of the suppies necessary to fabricate my own cables. Everthing you need is available at Radio Shack and/or Home Depot.
This will allow you to make up the length cable you need.....no more folded up excess cable to tuck away.
The cable and the RK-11 plugs depicted are from Home Depot...the crimper is fron Radio Shack.
