Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
Reload this Page >
Old P80 kerostart plug keeps coking up
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 07-28-2016, 06:45 AM
dorset john
Default Old P80 kerostart plug keeps coking up
I have an old (Pre-SE) P80 with a kerostart conversion. The kerostart ceramic plug keeps getting coated in carbon causing poor starting. I clean the plug by soaking it in carburetor cleaner and it then starts perfectly for a few flights, then cokes up again. I am using kerosene with aeroshell 555 at 5%.
Any ideas why this keeps happening and what to do about it?
Old 07-28-2016, 08:02 AM
stuart_80
I had exactly the same problem with the same engine and kero plug setup. I was using BP2380 oil.
Try using Mobil Jet II oil, at the same ratio. I found it reduced the "coking" a lot, and I hardly ever need to clean the plug. Maybe 2-3 times a year ?
Old 08-24-2016, 09:35 AM
morwan_gsm
morwan_gsm's Avatar
Never got any problem with mobil jet oil 2 and kero plug, try to change your oil
Old 08-24-2016, 01:06 PM
Dave Wilshere
BP2197 or Mobil 2 will cure the problem.
