Go Back  RCU Forums > RC Airplanes > RC Jets > Turbine Clinic > JetCat Turbine Direct Support
Reload this Page >
JetCat P400-PRO only generating 27kgf thrust
JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
Old 10-31-2018, 09:40 PM
eric_rico
Default JetCat P400-PRO only generating 27kgf thrust
I have a brand new P400-PRO series and have it mounted on a bench with load cell sensor attached in front of the engine. At max rpm 97,000, my engine only generate 27kgf on the load cell sensor. By the way the load cell sensor I use is iLoad TR series from Loadstarsensors and the environment in my workshop is <100m ASL and >50% RH. Can anyone tell why my JetCat is not producing enough thrust?
Old 05-18-2021, 09:56 PM
camicutta
Hi dear. Did you get the solution of your problem. I am also having same problem. The thrust is less and Exhaust temperature is also less
