JETCAT V10 Baro/Temp setting adjustment
Ok so on a new 160 Jet Cat (V10)
There is a Baro/Temp setting that can be adjusted,.
The Baro (eg1014) cannot be adjusted
On the second line mine will read for example Temp:37.0:-61.°C
When I try to do a user adjust I can adjust the last reading (the -61.°C) and change it to say 20 or what I like. Cannot adjust the first figure (37)
My question is what exactly is this reading and adjustment for.
The outside temp was 21 deg and this is correctly shown on the run page of the turbine as the turbine temp when its off and not been running so where do the 37.0:-61. figures come from.
Thanks....
Thanks....
