JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
90RXI help
Old 06-28-2019, 05:17 PM
jcterrettaz
jcterrettaz's Avatar
Default 90RXI help
Was flying my Rookie for two minute and the turbine stop.. landed safely then ground unit said : E C .. temperature error? why? the the temperature probe is damaged?
The little Jet Cat board in the jet flash non stop to.
And if I have to send the turbine to be check where is the place in the US?
Thanks in advance
Old 06-28-2019, 08:46 PM
Dave Wilshere
Could be the temperature probe died. You can change it yourself, two screws.
Turbine still spins? Everything looks OK otherwise?
Order a P-80 —P160 probe from DW. Use the Nylon mount from your turbines probe. When you re fit calibrate the temp again and you are good to go
Old 06-28-2019, 11:48 PM
CARS II
My Feedback: (7)
CARS II's Avatar
I'm getting the same massage but my situation is a bit different.
Making sure the cable wasn't faulty, I tested with another cable getting the same results then I plugged in my P60 to the comm cable and, sure enough, I got temp reading, I'm also getting the rapid flashing light.
I ordered a new temp prob from DW, about $60, like Dave said, simple to change.
Dave knows how to calibrate the new temp prob, I also have it if you need to know how, very easy steps to fallow.
Old 06-29-2019, 03:35 AM
jcterrettaz
Thanks for the help, one of my friend will give me a new probe . Yes Dave the turbine look fine otherwise .
Look like an easy fix ...
Now where you send Jet Cat for service in the US ( nothing in Canada) ?
Old 06-29-2019, 07:53 AM
jcterrettaz
Always learning...the ATV on my Rookie touch the sensor when I apply rudder and disconnect the 3 pins. Was easy to remove the cover with a special screwdriver . So well made inside ...
Made the sensor closer to the turbine body...everything work again
Old 06-29-2019, 11:36 AM
CARS II
My Feedback: (7)
CARS II's Avatar
Very nice! At least we know now for sure that the massage was because the temp prob wasn't working ( disconnected)
If your JetCat turbine is in need of service, send it to George at DreamWorks, before you send it, you have to fill up a request for repairs form, it's all on their website.
You'll also find some JetCat parts on their site.
Old 06-29-2019, 03:53 PM
jcterrettaz
Thanks you for the info's Carlos
the 90RX as only 20 minutes running time , everything is new and work fine, but I have an old Titan who will need service at the end of this year.
Old 06-29-2019, 07:54 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Very nice!
Here is where I fly.
Have fun, be safe
Old 07-02-2019, 01:30 PM
jcterrettaz
I fly yesterday and the 90RXI Jet Cat was perfect , I can't post video the role are not accepted?!
Im very please with the throttle response and very powerful for a 90
Old 07-02-2019, 04:37 PM
CARS II
My Feedback: (7)
CARS II's Avatar
Thanks for the report
Enjoy
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
