JETCAT 180NX not starting
HI ALL
Hoping someone can assist.
I have a Jetcat 180nx with v10 ECU but cannot get it to start.
The turbine ingintes and has a reasonable flame inside with the U-accel1 set at 250.
But as soon as it starts to ramp up, I suspect switch to U-accel2, the flame goes out and turbine does not start.
Engine just floods.
It looks like as soon as ecu start the accelaration and the starter starts increasing the rpm the flame is blown out or to much fuel and it "drowns" the flame.
U-accel2 I have tried at 600 amd was orginaly set at 750. ECU does not allow setting below 600 on this parameter.
Any ideas or help please.
KEN
Engine just floods.
KEN
Hi Dave
Thank you for the feedback.
I have tried the setting as sugessted, but no go. With Uaccel1 on 200 I do not even get a small flame.
Only on 250 above does a flame start inside.
But as soon as it starts the swithover the flame goes out and the engine floods.
NX is different to the 180 RXi I have so cannot say I can try different pump or so.
Pump is working and there is fuel in the engine ( keep on pouring it out afyer each failed start) but no ignition after the intial light up.
I cannot figure out why as yet.
Thanks again.
Thanks again.
What software version is in your ECU?
Try doing a complete reset hold Select menu button and power on. Hold for 40 secs
Re learn the radio and try a start
Dave
Dave
HI Dave.
Version says 10.4E.
Done complete reset and tried again. But no luck.
Took a video, but do not know how to or even if I could upload.
Guess the best is to send engine in to Jetcat for checking.
Regards
Kenneth
Version says 10.4E.
Regards
Kenneth
Ok, 10.4E is late enough. I guess to save time going back and forth get JC to check it, without seeing what is happening it’s difficult, but something is not normal.
Dave
Dave
Stuart
Morning all.
Thought I would give you a update.
I foind the fault. The kero feed pipe into the burner had pulled out. So only se fuel was goimg into burner and other was spraying into the casing.
Pushed pipe back and there we go.
Now done 10 starts and all sucessful.
Now I an go fly. :-)
Thanks for all the advise and support.
