JetCat Turbine Direct Support Ask your JetCat questions here for the experts that know them. MrMatt and Bob Wilcox will field your inquiries.
JETI Jetcat Telemetry
Old 08-07-2022, 06:31 AM
GBR55
Default JETI Jetcat Telemetry
I have a 10 hour JetCat 180RX with V10 ECU and set up the V1.1 JetCat telemetry adaptor running through a CB210 central box and 2 REX3 receivers . I also have a mini GSU mounted in parallel using a third ribbon cable to the i/o board . JETI DC16 TX and airborne RX/CB have latest JETI firmware .My GSU says the telemetry version is 8.6. I cannot identify the ECU version which from manual is meant to be 10.3 minimum. As this is a used turbine I do not have anything that tells me the ECU firmware version and can’t seem to find it on the ECU or on the shipping box.
The TX screen shows all my normal GSU data when powered up. I can spool the starter and get a reading on the TX screen along with appropriate run state; but when I initiate start the TX screen JetCat readout boxes start flashing and continue flashing until the RX is turned off. The mini GSU works perfectly throughout all this and I just go fly. I have ran the same setup with mini GSU disconnected and got the same flashing screen on start initiation. I have switched cable positions on the i/o board but it makes no difference . Flash flash flash until RX turned off.
I have previously used VSpeak on my 120SX with V6.xxx but had to jump through the Applications / JetiBox menus with a bunch of keystrokes each time I powered up for start. Not really convenient in the 21st century.
I went to JetCat Telemetry thinking it would be seamless.
Please help
GBR55
Old 08-08-2022, 03:52 PM
GBR55
A little update to the- so far- silent readers
I Disconnected i/o board and mini gsu and Telemetry works on TX windows when the sensor ribbon is plugged direct into ecu. I get full start information on the TX screen and telemetry throughout the run.
I then tried bussing the i/o board on the telemetry unit with a seperate cable to the i/o. As soon as I initiated the start it commenced flashing again. I cycled up through idle run and cooling and then shut down . Removed i/o cable and started it . When idle established I plugged i/o in and it continued to read properly right through to shutdown / cooling
So it appears to be a start up power draw issue.I do not see less than 9.5V on my 3s Life 4200 mah even with ignition pump and starter running start sequence and it will sit on 10V after start. All normal on my 3 JetCats
The JetCat manual shows the i/o bus connecting to the ecu and the i/o board as connection point for telemetry but on mine it appears to be the opposite.
It may be an ecu firmware update required and I will try to find out how to discover what ecu version I have from JC next week
In the meantime I will see what it takes to get my VSpeak on this ECU 10
The good news is that it hasn’t stopped me from flying
GBR55
Canadian Man (08-09-2022)
Old 08-08-2022, 09:32 PM
LA jetguy
LA jetguy's Avatar
Glad the recommendations worked.. possibly the telemetry module needs to be looked at and not require so much power to function properly..
David (Jonathan’s Jeti friend)
Old 08-09-2022, 04:49 AM
GBR55
Thanks LAjetguy!
Old 08-09-2022, 09:12 PM
LA jetguy
LA jetguy's Avatar
You are welcome 👍
