RCU Forums
-   JetCat Turbine Direct Support (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/)
-   -   Thrust Chart (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/10131906-thrust-chart.html)
Ayrtonsenna 11-12-2010 08:32 PM
Thrust Chart
Hi Guys, I'm after a thrust Chart / RPM for a Titan 160 running V6 Ecu
Cheers
seflyer 11-13-2010 02:11 PM
RE: Thrust Chart
I believe it is the same as the 160Sx minus the last rpm of 125,000 as the titan is 34 at 123,000, the additional 2000 rpm is due to the cnc compressor.
Kevin
Ayrtonsenna 11-14-2010 01:42 AM
RE: Thrust Chart
Ok... thanks for that kevin
