p80 problem
Hi
I have a small problem I hope u can help me with ………. My p80 that I have for a 1 year’s already I tried to run it and its propene start so when the sequence start after the ignition and engine go to 5000 rpm there is a fire in the Combustion chamber the engine dos not spoall up and I think it’s the fuel dos not go to the engine so I take the fuel bomb out and tray it its work only when the volte go’s 0.600 and up but lees than that it’s not working when u tray to test it from GSU ….. Is that normal or it should work from a lower voltage Thanks in advance |
| All times are GMT -8. The time now is 04:19 AM. |
