P-200 pump running high rpm when switching rc on
Hi!
Older P-200 with v5.1 ecu. Not run for couple of years. Converted to kero start. Previously about 30 faultless kero starts and about 5 hours total run time. Haven't changed anything during storage, same wiring and checked connections several times. 3s lipo ecu battery - also correctly teached ecu on that. And learn rc done. BUT when turning rc ON pump is constantly running on high rpm...pump definitely works because the pressure bursted a Festo fuel line behind a solenoid in maybe 2 seconds before I got rc-off! Nice (but scary) spray of kero! Reseted ecu but doesn't help. Seems like faulty ecu? Anything I have missed? |
Do you resolve your problem? I have the same on my JetCat P180rx
Originally Posted by scrogerio
(Post 12186056)
(Post 12186056)
If the Rx is doing it its another fault, do you have access to another Rx pump you can plug in and try? There are electronics in the Rx pumps. If not the turbine needs to go back. Dave |
Thank you Dave, I will try another pump and report.
My problem was pump, I try another and work perfect.
