RCU Forums
-   JetCat Turbine Direct Support (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/)
-   -   P140rx (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/11624188-p140rx.html)
Jetmech 12-02-2015 03:22 AM
P140rx
Hi I have a Jetcat P 140 RX and on the GSU run screen its showing a minus temperature of 24 degrees C, when I know OAT is nearly 30 degrees C ???? any advice ?
mr_matt 12-02-2015 06:18 AM
Calibrate it. You need to be at a place that is at 21c ambient when you do it BTW
