P20 sx no pump
Worked ok last year. No fuel while priming.
now no pump! Plug in system as normal. Valve clicks and pump runs w/o startup sequence???? Should not be running yet! Programing problem???? Weird!!! Any ideas???? Dave |
The P-20 pump is small if the gears were stuck you can fry the electronics. Anything smells 'smoked'?
You are saying the pump does run and prime fuel? Try a system reset to clear all the logs |
Hi,
All ok now reseated fuel/valve electric connections. Connector corropsion???? Thanks for help! Dave |
