Twin Jet Setup
Hello,
I have two Jetcat P250 Pro-S, I have connected the throttle with the "Y" method. The start-up and test runs of the jets were successful. I have read in the manual that there is a way that I can connect both turbines with TX RX cable, so they can communicate in order to resolve any thrust differential issues. I wired the 2 ECUs together with the TX RX cable, enabled Engine crosscheck and I made one primary and one secondary engine. But when I try to start-up the turbines, one with Immediate startup and the second one with sequence, one engine stays at LearnLO without giving me throttle authority. Any ideas? Kind Regards, M. |
Check out this. I put that under the jetcat users on Facebook.
maybe this’ll work for you. https://www.facebook.com/groups/4779...ibextid=W9rl1R |
