RCU Forums
-   JetCat Turbine Direct Support (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/)
-   -   which jetcat for first timer (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/4567292-jetcat-first-timer.html)
smokingtommy 07-31-2006 04:01 PM
hi i am toying with getting the boomerang intro as a step into jets i been flying for quite some time but which jetcat should i get there is 3 in my price range the p60,p70,p80
which one should i go for ? thanks for any help ;)
mr_matt 07-31-2006 04:50 PM
RE: which jetcat for first timer
Hello,
I would stronlgy recommend the P-70. The latest P-70s have very high power (>19 pounds/thrust at STP), low mass and very good fuel consumption, all at a very competitive price point.
We are about to build a another Boomerang at JetCat USA to demonstrate this combination so if you are at an event and see us there just ask for a test ride!
Regards,
Jason Burg 07-31-2006 04:57 PM
P-70 is defiently the way to go.
Jason Burg / JetCat USA / Technician
smokingtommy 07-31-2006 05:40 PM
thanks for help i was thinking along the same lines but was not to shore .and if it can put out the 16lb to 19lb of thrust i can see it will suite me for a long time to come as a friend has a nice fiber glass F15 in his loft but no jet engine not to shore on the full specs but he did say it needs 15lb of thrust and up . once again thanks wish i could come to the event but im in the uk and theres that thing called work
