RCU Forums
-   JetCat Turbine Direct Support (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/)
-   -   p-70 problem (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/5653014-p-70-problem.html)
banditarf robert 04-02-2007 08:39 AM
p-70 problem
yesterday i was flying my bandit with a p-70 and all of a sudden the motor shuts off with no white smoke, we land and it says fuel fail check the lines no bubbles, we did a full power run up, and tap the batteries and shook the hell out of the plane , nothing was wrong,
we decide to take it up again and all went fine,
then we were going to go up for a third time, turn the ecu and reciever on and it starts spinning because the ecu thinks motor is too hot , we put a blower through the intake and tempp doesnt drop one bit? any help would be great thanks
JetCatJimmy 04-02-2007 09:23 AM
RE: p-70 problem
I have had issues with the data cable before. If you jiggle the black "phone line" from the ECU to the turbine, it can read strange temps. Upwards in the 1065 degree range! So, check that first. It's a $4 part to fix the $8000 toy. Good luck![8D]
mr_matt 04-02-2007 01:03 PM
RE: p-70 problem
Hi Robert,
I sent you a PM, it is quicker to talk over the phone than trade messages, hope that is convenient with you!
Regards,
