Jetcat ecu setup for atv
I am flying a p60 in a boomerange intro with Futaba and the Extreme link module. All is ok, but not sure if my setup is correct. Should the atv be set on +-100% for throttle???????? It is set-up with failsafe in the receiver and on ppm. I believe that I followed the directions per the manual. Is this the correct set-up???
Thanx, Dave |
RE: Jetcat ecu setup for atv
you should set your travels to 100 +/- and set the failsafe with them at this ATV. you should then adjust them to 75 +/- and do a Learn RC and leave them there. you should then get the F on the GSU when you flip the TX off as a check.
As log as you can confirm the failsafe (by either noting the "F" in the main menu or the failsafe counter incrementing in the RC Check menu) your settings are fine. The ECU adjusts for the full through during the calibration process. (RCLearn)
Hope that helps, |
| All times are GMT -8. The time now is 12:33 PM. |
