RCU Forums
-   JetCat Turbine Direct Support (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/)
-   -   error on remote gsu (https://www.rcuniverse.com/forum/jetcat-turbine-direct-support-151/7875273-error-remote-gsu.html)
laser line 08-22-2008 07:38 PM
error on remote gsu
looking for advise on what could be the problem i'am having .i removed the complete turbine system minius the 2.4 gig reciever for one jet to the new jet. i teach the ecu to the new system. the turbine will not start and i get an (e) flashing over where the temperture display on the remote gsu
thank you
Rob
Thud_Driver 08-22-2008 11:55 PM
RE: error on remote gsu
Often enough this is a problem with the black data cable between the ECU and engine. Try a different cable or disconnect and reconnect at each end.
mr_matt 08-23-2008 07:56 AM
As Rick said, the cables can be swapped, all of the data cables that came with your turbine can be interchanged.
Do NOT use a cable from the Radio Shack or something, they are wired differently.
It is very easy to make your own cables but you need a special crimping tool.
If that does not cure it, then your thermocouple is bad. I THINK JetCat USA sells them seperately now and you can change it out at home if need be.
Regards,
laser line 08-23-2008 09:14 AM
thank's for the info found that that thermo coupling had a broken wire thank's again
Rob
E.N.T. 09-15-2008 11:01 AM
This is for Mr. Matt. I live here in Puerto Rico, and would like to know which type of data cable and the one that goes from thee ecu to the light hookup is and where I can get it if it's not the one from Radio Shack???
Hector
Edgar Perez 09-15-2008 02:10 PM
ORIGINAL: hmarmaizmd
Hector
Hector,
Check [link=http://www.rcuniverse.com/forum/m_6092071/anchors_6092071/mpage_1/key_jetcat%252Cdata%252Ccable/anchor/tm.htm#6092071]this post[/link] and [link=http://www.rcuniverse.com/forum/m_3465801/anchors_3465801/mpage_1/key_jetcat%252Cdata%252Ccable/anchor/tm.htm#3465801]this other one.[/link]
I'm already working from europe... looking forward to Jetpower
