Turbo prop help needed
I am at bomber trying to asist someone in getting a turbo prop running. On the start sequence it spools the turbine and then fails to a low temp. It never lights off on propane. I have cheked the fuel pump and solenoid. As well as the propane solenoid. That is testing fine. Can someone call me on my cell phone or leave a number for me to call. 7133043818. Thank you
RE: Turbo prop help needed
Hello,
The glow plug is either bad or not getting hot enough. Make sure at least 1/8 inch of coil is pulled out and that the coil is not shorted to the plug body. Start bumping the plug voltasge up, with a Rossi I would go straight to 2.6v minimum. You might also want to lower the starting gas percentage down 10% from wherever it is set now. Regards, |
| All times are GMT -8. The time now is 12:29 PM. |
