Which battery type?
I recently had my v6 ECU upgraded by JetCat to use A123 batteries. On the GSU battery setup, I only see options for NiCad and LiPo. What battery type should I select to set it for A123's? Also, my motor is an older P80. When the GSU boots, I see P120 on the startup screen. Do the P80 and P120 use the same program or do I need to have it re-flashed.? Thanks ...
Never mind ... called JetCat and got the info. |
RE: Which battery type?
I just got mine back from JetCat after the A123 update. So which batter type do you select for the A123? LiPo or NiCad?
Thanks Graham |
| All times are GMT -8. The time now is 08:24 PM. |
