Charging DX8 transmitter battery
Point is, I would NOT trust the built in charger with a NiMH pack. Either pull the pack and charge with good equipment or make an adapter and install an external charge jack on the cover. Sorry for the rant at the end of the last paragraph but it frustrates me when companies take that position. Especially when it would have cost them less than 15 bucks (their cost for a new pack) to keep a happy customer that spends thousands each years on this hobby, much of it with them. Oh well I guess I have choices (there's always Tower and also the Chinese) so why complain.
I just bought a NEW DX8 from Horizon Hobby a few weeks ago.
The battery voltage was 4.8V, so I plugged in the wall charger and started charging the battery..
After 4 hours and 50 min the DX8 was getting hot! I removed the battery door and the NiNH pack was 115 Deg F. I called Horizon Hobby and they said to send it back to them...
Jezmo do you know how hot yours got?
I’m sure if they replace it,,,,,,, the new one will do the same.
I don’t want to remove the battery every time I charge it.
And now,,, How can I trust it to charge a LIPO?
COME ON HORIZON HOBBY WHAT ARE YOU THINKING????
When I called HH the guy on the phone acted like he never heard of this before.
And could not tell me what the max temp should be, Just that it is to hot.
Futaba is looking better and better.
When I called HH the guy on the phone acted like he never heard of this before. And could not tell me what the max temp should be, Just that it is to hot
If you think Horizon has crummy CS, wait 'till you deal with Hobby Services....
115F is not too hot. You can take them up over 125 w/o a problem.
The power to the battery is limited to 200mA = 1/10C, a trickle charge. What is the voltage? Have you checked it on an external charger to see if it has peaked yet?
Andy
Hi Andy
When I charge a 4.8V NiMH pack, I’ll charge it at 1A or 1.5A and have the temp safety cut off at 100Deg F. This should charge the battery around 85 to 90 % full.
Charging with the temp over 115 Deg F will shorten the life of the battery.
When I called HH and told him what battery temp I was getting he told me it was way too hot and I needed to send it in……I ask him to check and make sure that the battery temp of 115deg F was too hot before I send it in. I did not want to send it in for nothing.
So is the guy answering the phone at HH knowledgeable on the product?
Onlybatterypacks com
NiMH Battery Pack Maintenance
1.) If you are having trouble charging your NiMH battery pack –trickle charge at 1/10 C (capacity) to wake them up and reach full capacity.
This also applies to packs that have been in storage.
2.) Trickle charge time listed in the chart above is for fully discharged packs.
Always let the batteries cool to room temperature before charging. Heating your NiMH battery pack up beyond 110 F degrees indicates
an overcharge condition and will lead to cell damage, loss of voltage and capacity.
3.) Nickel-Metal Hydride cells are more sensitive to heat than Nicads, so be sure not to overcharge them. Overcharging may cause the cells
to vent and loose capacity. It is recommended that you charge with a charger that has an adjustable Delta Peak detection circuit (set to
.01-.02v) eliminating the possibility of overcharging. Nickel-Metal Hydride cells will quickly get hot after the voltage starts dropping, so
keep track of the time on the charger.
You can either refer to the voltage, or you can let it charge for 10 hours and call it ''charged.'' The charger will go into trickle charge once the pack is full.
Andy
I would like to do what I did with my DX7, and that is cut the cord off the wall charger, attach a Deans plug and use my Hyperion charger set for a max current of 200ma and a time cut-off. Of course this way it will not detect a full charge and stop charging on the timer, which in my opinion is safer than the built-in charger that doesn't shut off and in most cases overcharges if left on charge too long.
Up date
HH called and said that 115 Deg F when charging the DX8 with the 4.8V 2000mAh NiMH is ok..
Then I reminded him that HE stated in our first conversation, that 115Deg F was way too hot and may have damaged the DX8, and I needed to send it in.
Now 5 day’s later 115 Deg F is normal ….
Nothing,,, Drives me more than incompetence…
Onlybatterypacks has this on the website.
Jezmo you’re right !! for now the battery is coming out when charging.
This winter I'll check into converting everything over to Futaba.
You could also get one of those 110V timer deals used for outdoor lights, etc - just set it for however many hours you want to charge, start it, and pull it off the next day before the charge cycle starts again.
I do like the idea of the added charge jack - that way I could use my Ace digipulse with adjustable current and auto trickle. Hm. Might have to look into that.
The issue is the battery temp can get 115Deg F ( over charge) or more in a few hours.
How long would you set the timer for?
I think a good Peak charger on the battery is the way to go (( Like Jezmo has )) until HH can fix the issue ........
Or just go with the lipo,,,,,,, and charge it out side in a lipo bag just in case it over charges!!!!
Depends on how low the voltage gets before I charge it. If it gets clear to 4.2V or so, I'd probably do ten hours. If it's still 4.8 or above, probably only 3-4 hours.
will you please check the battery temp when you charge it and let us know how hot it gets ??
Thank You...
Do they all get hot or just a few????????????/
I'll see if I can dig out my thermocouple probe one of these days, but don't hold your breath. I don't charge it very often, don't get that much chance to fly!
Pete
Harry
Jezmo, thank you for the picture. When you charge the battery, does the DX8 see the volts, or just the battery ????
FYI update,
Hi Jezmo and all.
I tested out the DX8’s charging system.
As you can see in the picture, the charging Volts, charging Amps, and battery temperature data was taken.
If the battery was charged inside the DX8, the battery temperature could get well over 115 deg F.
This high temperature can be mistaken for an over charged battery condition.
The high battery temperature is a result of the battery being charged and the DX8’s internal charging system adding heat inside the DX8.
If you remove the battery door on the DX8 when charging, (to allow ventilation) , the battery will not get as hot.
Gary
