JR X9503 suddenly stops transmission HELP !
Hello,
After less than a weak of using my new JR X9503 transmitter , I suddenly lost transmission and the status LED on the back of the transmitter turned off .The display is normally functionalbut with notransmission. Can anyone help please ! is it a fuse problem ? I appreciateany suggestions.<o></o>
Thanks,<o></o>
I appreciateany suggestions,
Thanks a lot,
Thanks for the posts, I think its not a fuse problem because a fault fuse cut the power for the entire system , the thing is I afraid that if I open up the transmitter I void the warranty , do you think that openning up the back to check the connections voids the warranty ?
I appreciate any suggestions,
Thanks a lot ,
Thank you guys , the problem has been solved ! , I opened up the device and found a wire connector that is not properly placed , I secure it in place and the transmission is on .<o></o>
Thank you for your support ,<o></o>
Best regards ,Thank you guys , the problem has been solved ! , I opened up the device and found a wire connector that is not properly placed , I secure it in place and the transmission is on .<o></o>
Best regards ,
