AR400
My Feedback: (9)
IL
I just got my new AR400 rx's and I even read the inst. my question is does the negative side go to the outside or inside of the RX.
I will be using the first one in a 4ch glow model and I will use a standard Y harness does it matter if I reverse that channel I will most likely use the throttle channel.
Thanks Greg
Thanks Greg
My Feedback: (61)
Why use a Y harness in a 4 channel model? There are separate connectors for each of the 4 channels and the battery.
Looks like the battery - goes to the end of the case (outside). The label on it shows the signal, then plus, then minus as you go towards the end of the case.
I just picked one up today, about to head home and bind it to the TX just because..
