JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
DX 8 Question 2
Old 07-05-2012, 02:59 AM
p300pilot
Default DX 8 Question 2
Just some questions - once I have a Model set up in my DX 8 with name, wing and tail etc. is there a way to get back into the wing and/or tail configuration without having to erase the model and start all over again ? Secondly, if I have a wing with 2 servo's for the ailerons but power these through Y-cable, do I set up the wing configuration as having 1 servo ? Hope to get an answer as I have scanned the manuals and could not find anything related.
Cees Smit
Emmerich am Rhein
Germany
Old 07-05-2012, 05:12 AM
BuschBarber
Default RE: DX 8 Question 2
ORIGINAL: p300pilot
Cees Smit
Emmerich am Rhein
Germany
As you know, the Wing Type and Tail Type are accessed through the System Menu. You can enter the System Menu and change the Wing and Tail Types for any Model Memory as many times as you wish. You can use Model Reset to wipe out all the parameters in a particular Model Memory or change whichever parameter you wish.
The Wing and Tail Types are mixes, just like any other Programmable Mix except that the DX8 decides which channels will be mixed. If you only have a 6 channel Rx and the Wing Type chooses Aux2 for one of the channels, you have to change the Wing Type to Normal and use a Programmable Mix to get the result you want.
If you use a Y Harness to connect two Aileron servos to Channel 2, you cannot use the Wing Type of Dual Aileron. You cannot adjust each servo on a Y Harness, independently, from the Tx. You would need to do that Mechanically or use a Matchbox.
Old 07-05-2012, 05:31 AM
p300pilot
Thank you but that doesn't work. If you go to the sytem menu and select the model you want to change by pressing the roller > you are automatically out of the system menu. Am I overlooking something ?
Cees
Old 07-05-2012, 06:31 AM
grizzly59
grizzly59's Avatar
You must be on the model you want to set up first. Then go to the system menu. That menu is for the model you have already selected. Then if I remember correctly you go into Wing type and that is where you make your changes.
Old 07-05-2012, 06:35 AM
BuschBarber
ORIGINAL: p300pilot
Cees
There must be something wrong with your DX8.
I hold the Roller and turn on the Tx power to access the System Menu. I can go to Model Select, choose any Model, and change any parameter, and back out to the System Menu. The only way to leave the System Menu is to scroll to Main Menu and press the Roller, or Turn Off the Tx.
Old 07-05-2012, 06:37 AM
p300pilot
Thanks guys, I'll give it a try tonight
Cees
