JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
JR 12x with "black" display
Old 08-22-2012, 04:14 AM
mundsen
Default JR 12x with "black" display
Hi!
I have purchased a used JR12X that have a display fault.
WhenI turn on the radio the display is "black" (not blank). But if I look at it from the side, I can se all the info on the display - navigating in the menus.. works fine.
I have tested adjusting the contrast, but I get no reaction.
Must the LCD panel be replaced, or can it be something else?
Best
Oyvind
Old 08-22-2012, 04:34 AM
mundsen
Default RE: JR 12x with
Tried to upload images
ID:	1794288   Click image for larger version
Old 08-22-2012, 05:39 AM
Zeeb
My Feedback: (41)
Zeeb's Avatar
Try adjusting the screen contrast.
Old 08-22-2012, 06:47 AM
mundsen
I have tried adjusting the contrast, and get the normal beeps when scrolling the wheel , but the display stays the same.
Old 08-23-2012, 03:55 AM
mundsen
I did remove the back cover on the radio to fix the battery cover (was lose).
When I then turned on the radio, I get 4 beens and the message "Backup error 0"  :-(¨
MacGregor Industries told me that the cpu pcb must be replaced, and that the pcb costs 273GBP + it must be re-calibrated.
So then I think that I give up fixing it :-(
Is there a service menu that I can try to access?
Anyone here that have a CPU pcb to sell?
Old 08-26-2012, 12:04 PM
mundsen
Opened the radio today, and found a faulty component on the "switch PCB"
It is component C292 and looks like a diode?
Anyone that know what i can use to replace it? Can I insert a voltage to the pin on CNPEB to do a test?
I´ll try to upload a image
Old 08-27-2012, 11:14 AM
slarty
C292 is a 10uF 20V capacitor. It sits across the battery supply (+Vcc), for that to blow like that, it would be either a reverse battery or high battery voltage.
You can remove it but doubt very much if it would cure the fault.
Old 08-27-2012, 11:42 AM
mundsen
ok
Do you know the voltages on the pins on the CNPEP connector going from this PCB? So I can compare them
Old 08-27-2012, 03:56 PM
slarty
CN-PEB are as follows...
Pin 1 - +5V
Pin 2 - Sounder Pulses
Pin 3 - + Batt Voltage
Pin 4 - + Batt Voltage 9+Vcc)
Pin 5 - + 3. 8V approx ( 0.4 Batt Voltage )
Pin 6 - Ground
Old 08-27-2012, 11:40 PM
mundsen
Thank you!
I´ll meshure them when I get home from work.
Is there a servicemenu or some other trick to solve the Memory error message, or do I have a faulty CPU PCB?
Oyvind
Old 08-28-2012, 08:57 AM
slarty
There is a service menu but it requires the setto be fully functional in order to access it.
Old 08-28-2012, 10:14 AM
mundsen
The voltages seems ok, so then I guess the CPU Board is defective :-(
A new board is to expensive
It is to hard to trash the radio, so I consider modify it using a ersky9x board.. (winter project)
Thank you for the help
