JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Dx7 elevon setup
Old 08-29-2012, 02:55 PM
stevegauth30
stevegauth30's Avatar
Default Dx7 elevon setup
Can any one help?im trying to set up a plane with elevons, and can't figure it out. I've done it in the past with a different radio, so I understand the concept of what needs to happen, I just can't get it. I've tried reversing servos on both sides, I've tried switching the wire on the RX between ail, and elevator. There's always one elevon that's reversed. It's fine on the left and right, but when I pull back or push forward, it's like ailerons. One up and one down. Can anyone help?
Old 08-29-2012, 06:23 PM
BuschBarber
Default RE: Dx7 elevon setup
ORIGINAL: [email protected]
Connect the Right Aileron to the Aileron Ch2 and the Left Aileron to the Elevator Ch3. Select the Wing Type of Elevon. Go into Servo Reversing and adjust the direction of Ch2 and then adjust the direction of Ch3 until both Elevons are moving in the correct direction. Until you do this you do not want to change the Travel, Subtrim, Dual Rates/Expo for either of these channels. They should be left at Factory Defaults until the Wing Type of Elevon has been selected.
Old 08-29-2012, 07:02 PM
stevegauth30
Thanks a lot . I'll give it a try.
Old 08-30-2012, 07:39 AM
stevegauth30
That was it my friend. Worked perfectly. Thanks.
