dx6i programming
dx6i programming
Can someone please tell me how to program elevons using the dx6i? I have a flying wing and an orange 2.4 rx and I can't get the elevons to work. I have one servo plugged into the aileron port and one plugged into the elevator port. I can't seem to find the mix to make them work together. Thanks Matt.
CA
RE: dx6i programming
You must go to the Wing/Tail type mix menu and enable Elevons.Then play with the reverses or possibly swap the where the servos are plugged in to get everything working in the correct direction.
