DX7 using Mix switch to operate Gear Channel
My gear switch is configured to operate the ignition on the gear channel of my DX7. Instead I want to use the Mix switch but did not manage to setup the right mix to do it.
Can somebody help me.
If so then go to System Setup and then Switch Select menu and set Gear to Inh and then set Mix to Gear(reassign Gear channel from Gear to Mix).
I had to go into one of the menus to get my flap switch to function.
Gary
Yes I'm referring to the Dx7 not the S. The name of the switch is Mix Rudder D/R located on the right top corner.
Its been awhile since I used mine.Ill have to drag it out and play with the mixes to see if I can come up with what you want.
Right off the top of my head first you need a Gear>Gear mix of -100/-100 to disable the gear switch from the channel.Then I think you will need to create a second mix of Gear>Gear assigned to the Mix switch and set values.I kind of remember having issues trying to do this some time back.I dont recall if I got it to work then.I kind of remember only being able to move the value over half the channel that way.I might not remember it right.Its been awhile.
If you can tell me the values on the gear channel for Off and On ignition Ill play with it and see what I can come up with.
Thanks for the tips of the two mixes. I was able to set it up it but honestly not very easy.
The new generation of mid level DX radios(7s&8) are a huge step forward in ease of programming.
They now have a DX7s. The DX7s has telemetry capability and a SD Card Slot. I assume you got just a DX7, which is a good radio. However, if you are flying Giant's with it, 7 channels could be a show-stopping limitation. Also, If you want to use telemetry to see Engine Temps, RPM, Rxer Voltage, etc read out on the transmitter, then you do not want a DX7. A DX7s or DX8 would be what you were looking for to get these features. Of course you could drop a lot of $s and get a DX18 and not have any limits, until they come out with the next new model.
They just had a DX7 sale and threw in a couple extra Rxers to get rid of the older model. One of my club members just bought one. So far he likes it.
I am not sure how you would check the software version on DX7. On a DX8, that info is found in the System Setting screen. I am not sure how you would update a DX7. I know my DX6i was stuck with what was on it. The DX6i does NOT have an SD Card Slot. If your DX7 has a SD Card slot, you can get the latest rev software fromwww.Spektrumrc.com.
I know when I got my second DX8 a few months ago, it was three software revs old.
Anyway, the reason I posted was I do not think I have met you. I go thru Hesperia all the time. I live up in Baldwin. Are you flying with Port City RC or TailTwisters?
I just bought a like new DX7 TX. How do I know if I got a old version or newer version? It has a rocker switch to select data inputs on the bottom left of TX. Is it a good radio??? Thanks
The DX7s can be updated by you with just an SD card and an internet connection.
Andy
Andy
The upgrade is free. Go to the Spektrum site and register the DX7. Then search around for the link to the upgrade. Then download it to your computer. Transfer the upgrade to the Transmitter using the SD card.
How much $$ for the upgrade???? Any Idea.....Thanks
[/quote]
http://www.horizonhobby.com/products...only-SPMDX7UPG
[/quote]
[/quote]
Got error code 404............
What do you mean you got error code 404? When did you get it? Does it clear when you shut if off and back on? Is the battery fully charged?
If you are getting an error code, you probably are going to have to send it back to Horizon Hobby. Then., I would get it upgraded. Otherwise I would not bother with it, if you can get past getting the error code.
I would PM Andy Kuntz and ask him what the error code means.
The link worked great for me. It might differ if you're trying to use a mobile.
Andy
