JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Jr x9303 and servo travel
Old 10-12-2013, 04:16 PM
Stick 40
Default Jr x9303 and servo travel
I am putting together a new plane and am using my 5 year old x9303 2.4 radio. I have set the D/R to max and the trvl adj. to max and only get about 1/4in. travel.
is there any other place on the radio to adj. servo travel, I have went thru the book several times.
sticks
Old 10-13-2013, 03:21 AM
airbusdrvr
Did you do a Model Reset before you started this new setup? If not, there could be something left over from the previous model.
Old 10-13-2013, 12:19 PM
Stick 40
I did not do that at first, but when I got into trouble I did a model reset..
I think I will do two resets in a row, I think I had to do that at one time on a plane that would not come around.
But I think the real problem is in the RX, its a new one with a lot of bells and stuff. It has the 3 channel gyro , etc.
Old 10-13-2013, 01:02 PM
Stick 40
ok, I went back and reset model twice and no help. everything else is good!!!!
well the motor ( elect) stays at 30 amps no mater what prop I put on it. I went from a 13/8 to a 15/7 and still draw 30 amps.
I started to wonder if I had a bad servo, so I plugged the elev into gear and mixed gear and elev.
I have all kinds of up elev and limited down ( down is still enough to fly it ) what's up with that????
big problem, by doing this I lose the gyro for the elev !!!
Old 10-13-2013, 01:45 PM
Stick 40
I went to the spectrum site and found a video on programing the ar635, every thing is fine now.
no fun learning how to do it right !!!!!! LOL
sticks
