JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
DX9 idle down?
Old 12-04-2015, 08:32 PM
shford
My Feedback: (27)
Default DX9 idle down?
Does the DX9 have an idle down function I can assign to a switch to use when I taxi back to the pits? Can't find it in the manual.
Sam
Old 12-05-2015, 08:55 AM
AndyKunz
You would do that with a throttle curve.
Andy
Old 12-05-2015, 02:49 PM
rmh
rmh's Avatar
I must have slept thru that class--------
a mix on a switch was my approach.
Old 12-05-2015, 04:06 PM
AndyKunz
"Idle down" is top-end throttle limiting, not setting a fixed throttle. The throttle still works, but it only goes so high. Germans have been asking for us to add it to the radios for a long time.
Throttle Curves do this nicely. A mix doesn't.
Andy
Old 12-05-2015, 05:20 PM
shford
My Feedback: (27)
I switched from Futaba. Idle down allowed me to flip a switch and my idle would drop to a lower setting. I didn't think of it as throttle limiting as you mentioned. You are saying throttle curve does the same thing?
Old 12-06-2015, 02:41 AM
RAPPTOR
My Feedback: (41)
Yep .i put my mix on ,high rate rudder
full stick is taxi speed. Plenty steering .
Throttle cuve is how i did it.
Old 12-06-2015, 06:55 AM
rmh
rmh's Avatar
Andy
That's a head scratcher
"Idle down" refers to limiting high throttle ?
I would have called it throttle limiting .
Old 12-06-2015, 12:10 PM
AndyKunz
For lower idle throttle just trim down. Throttle trim only works on the low side of travel.
You know how meanings sometimes don't always come through from other languages?
Andy
Old 12-07-2015, 12:48 PM
louc64
Ok here's the fix. I used a mix and set it to the throttle on the "H" switch. Now it works just like my futaba radio for the idle up/down however you want to set it.
throttle curve does not work for the idle up/down. Throttle curve only changes the linear action of the throttle curve. Not the limits of the throttle.
Old 12-07-2015, 12:55 PM
AndyKunz
For throttle curve, you would have moved the bottom left corner upwards in the places where you wanted throttle low-end limited. In the curves where you wanted it farther down, you'd have left it there.
The mix works for you, so that's good. Enjoy!
Andy
Old 12-07-2015, 06:45 PM
louc64
I'll try that to. Thanks for all the help!
