JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Receiver 831B Led Cant Light up
Old 05-27-2020, 09:32 PM
masmara
masmara's Avatar
Default Receiver 831B Led Cant Light up
I have Rx 831b, so long don't to use
yesterday i would to used
tihis is my binding procedure
1. I am assured my power with life 2 cell
2. plug binding conector to bind slot at Rx
3. plug power kabel to one of chanel
after procedure led cant light up
what happen with my rx ???
thank
Old 05-28-2020, 04:11 AM
A. J. Clark
A. J. Clark's Avatar
Check that the power wires are in the proper orientation.
Old 05-28-2020, 04:35 AM
masmara
masmara's Avatar
i assured and i follow the diagram like in PDF {rx instalation)
File Type: pdf
Old 05-28-2020, 05:55 AM
A. J. Clark
I don't see in the diagram were it shows polarity for the power wires so I would try changing the orientation of the power wires.
Old 05-28-2020, 03:51 PM
A. J. Clark
If you turn power lead around and still don't get any lights to come on then take your ESV meter and plug it into another receiver slot to see if there is any voltage on the pins.
Old 05-29-2020, 11:58 AM
AWorrest
Is the remote antenna connected to the receiver? On the RG731BX which I believe is based on the 831 design, the receiver blue LED will not light and it will not bind unless the remote is connected.
Allan
Old 05-30-2020, 01:32 PM
AWorrest
Correction:
Working with the 731BX a little more after making the previous post, I was too hasty in stating the main unit blue LED would not light unless the remote unit was connected. It will start flashing after a delay of more than eleven seconds from powering on. However, I wasn’t able to get it to bind without the remote connected.
Allan
Old 06-01-2020, 05:46 AM
masmara
masmara's Avatar
Allan
i will to bind my JR remote with this RX
the first step i am connect this rx with power (LIfe 2 cell)
but my rx blue LED dont light up
Old 06-03-2020, 04:42 PM
AWorrest
As mentioned before I don’t have an 831B receiver but rather an RG731BX which uses the same remote antenna and case as the 831B. When my 731BX receiver is placed in bind mode with the transmitter off, the blue LED does not turn on immediately with application of power to the receiver. It takes more than eleven seconds after power is applied to the receiver before the blue LED starts flashing. This can seem like an eternity if you are expecting it to be on instantaneously.
While the slots are keyed for JR connectors, it is possible to plug in the battery backward. On the horizontal row for the servos - with the receiver label up, the top row of pins is negative, the middle row is positive, and the bottom row of pins are the signals.
Make certain that you have the bind plug in the sensor/bind/power connector slot and not in the AUX3 slot. A defective bind plug could also be the problem. If you are using a home-built bind plug, the two outer contacts should be electrically tied together and the middle contact is left open. If the bind plug is defective or placed in the wrong slot, the blue LED will never flash.
Finally, it is possible you have a defective receiver. Good luck.
Allan
Old 06-03-2020, 08:32 PM
masmara
masmara's Avatar
As mentioned before I donít have an 831B receiver but rather an RG731BX which uses the same remote antenna and case as the 831B. When my 731BX receiver is placed in bind mode with the transmitter off, the blue LED does not turn on immediately with application of power to the receiver. It takes more than eleven seconds after power is applied to the receiver before the blue LED starts flashing. This can seem like an eternity if you are expecting it to be on instantaneously.
Allan
thank you, i will try this
Old 06-03-2020, 08:40 PM
shahzad haider
thank
Nice
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
