JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
one elevator servo moves before the other
Old 06-04-2020, 04:25 PM
j.c.a.
Default one elevator servo moves before the other
I have separate channels for elevator as I pull on stick right elevator moves about a 1/4 of an inch before the left elevator servo starts to move. has anyone encountered this issue?
DX20
SPMAR20310T
Old 06-05-2020, 03:14 AM
rgburrill
rgburrill's Avatar
That must be fun. Does the DX20 have channel delay? Does this show up on the servo output display or just on the servo?
Old 06-05-2020, 03:47 AM
BarracudaHockey
BarracudaHockey's Avatar
Swap the elevator servos at the rx and see if the issue follows the channel or the servos.
That and export the model and attach the resulting SPM file here so Andy K or I can take a look
Old 06-06-2020, 06:11 AM
j.c.a.
Thanks for the response guys, I am out of town for a couple days as soon as I get back I will try your suggestions. Once again thanks
Old 06-09-2020, 05:39 PM
j.c.a.
Well I Tried the following,
Different Receiver
Different Extensions
Different Radio
Changed servos
Checked for play in linkages
swapped channels right to left and issue stays on right elevator
eliminated the gyro
the setup is as follows three fight modes
A, normal flight normal elevator no Flaps
B.normal elevators take of flaps 15 degrees
C. normal elevator landing flaps 40 degrees
Mixes
A. vector thrust normal elevator
B. vector thrust with elevon
Issue is present in every flight mode and every mix
I ran out of talent, lol
Old 06-09-2020, 06:04 PM
j.c.a.
this is the file
File Type: spm
File Type: zip
Old 06-10-2020, 11:23 AM
AndyKunz
You can improve timing performance slightly for the X-Plus channels by moving RLv from X+3 to X+5, and changing X+3 back to Inh.
You can improve the performance of the entire system by moving the items you have on X-Plus channels down to channels 6 & 7 and changing ALL the X-Plus channels to Inh. You need to keep the 22ms Frame Rate setting because you are using more than 10 channels.
Let's try something. Go to the Rx Port Assignments screen (select Channel Assign on the System Menu). On this screen, go to channel 8 AUX3 and change it from Aux 3 to R Elevator. Move the servo plug from channel 3 to 8 also. Do you now see a difference now? In this mode, the two channels are sent at exactly the same time to both servos.
Andy
Old 06-10-2020, 12:00 PM
BarracudaHockey
That's what I was going to say but he beat me to it
Old 06-10-2020, 05:09 PM
j.c.a.
Andy
Thanks for the quick reply, will try, is it possible to talk on phone? 305-213-3700
Old 06-10-2020, 06:02 PM
j.c.a.
Hi and once again thanks for the help,
Changing X3 to X5 should not be a problem but Channels 6 and 7 I don't understand they are being used , here is the cannels as I am using,
1- Throttle
2-Right Aileron
3-Right elevator
4- Rudder
5-Left Flap
6-Left Aileron
7-Right Flap ( Aux2)
8-Gyro on/off and a combo mix with gear channel for high and low gyro rate (Aux 3)
9-Left Elevator (Aux 4)
10-Gyro on/off Vector Thrust (Aux 5)
11-Vector Thrust Rudder Servo (Aux 6)
12-Vector Thrust Elevator Servo Aux 7)
13- Gear (X-1)
14 ---------------------(X-2)
15- Brakes (X-3)
16 ---------------------- (X-4)
17 ---------------------- (X-5)
18- Steering (X-6)
19 ----------------------- (X-7)
20 ------------------------ (X-8)
J.C. Alvarez
Old 06-11-2020, 04:53 AM
AndyKunz
Yes, I was thrown off by them being mixed opposite what is normally done. It's usually better to put the input onto a channel in the Channel Input Assign screen, and then use a mix with -100% rates to disable it. That way it's clear what is being done.
You should always put your gains and switches on the X-Plus channels. Move channels 8 and 10 up to X-Plus. That will free up two channels for flight controls.
That would allow you to copy the right elevator to Aux3 as noted above.
Andy
