JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Spektrum AR637T battery question
Old 03-11-2021, 10:27 AM
Hansen_l
Default Spektrum AR637T battery question
I am new to Spektrum, have been using Tutaba for 30+ years but decided to try the AS3X so got me a DX8G2 and a AR637T receiver to put on my new 1/4 Citabria (gasoline) but I don't see a battery port on the receiver. Where does the battery connects, to channel 6 or to the binding port? If I connect to channel 6, them the recover goes from being a thru 6 channel to being a 5 channel.
Old 03-11-2021, 10:47 AM
BarracudaHockey
BarracudaHockey's Avatar
Any open port, you can Y it to the rudder or something if you run out. The bind port will work if you're only using +/- and not something that will ground the signal to ground, that's how a rx is put into bind mode.
Old 03-18-2021, 08:29 AM
Hansen_l
Hey Andy, Thank you very much for your answer. I will do as per your answer, Thanks.
