Need latest software/firmware of JR 11X Zero radio (version 0002-0003?)
Good afternoon All.
I'm from Indonesia. Last week I won an auction from eBay, an old stock brand new JR 11X Zero transmitter with a DMSS module attached and binding to the RG831B receiver. The radio itself has firmware/software version 0002-0001. I have checked all the channels on the RX, they are all OK. And the RX battery voltage (with satellite attached) is also displayed on the TX screen.
I've done some research that the latest software version of the JR 11X Zero is version 0002-0003 (I don't know if there should be a higher version than that for the JR 11X Zero) but none of the links are active.
If someone can help me get a link to download the latest firmware/software version specifically the JR X11 Zero - NET-P111ES model, that would be greatly appreciated.
Thanks & best regards
The JR 11X Zero was never sold in the United States. Have you tried contacting the new parent company in Japan at https://www.jrpropo-jp.com/ ? They don’t list your transmitter on their download page; but, they may know where updates for it can be found. If I recall correctly, the Zero had a hardware update. One change were the rate switches. They went from a two-position switch to a three. Mention the hardware configuration when asking about an update. If you have the original hardware configuration, there may not be any software updates for it.
Allan
Allan
karmensarodja (09-26-2021)
Does the 002-003 software have the stick mode feature in the system menu. I need the feature in my jr x-11 for mode change from mode 2 to 1. I updated the firmware from 0001 to 0002 but this feature is not there.
@shabbirbhagat, sorry to jump in… for 11X Zero, even since version 0002-0001, this feature already exists. I remember when I received the radio and every time I finished making a new model, there was always a Throttle warning, it seemed like my radio was originally in mode 1, then I had to set, somewhere in the menu, to mode 2, according to the current position of the radio stick.
After I installed firmware 0002-0003 from bjw4072, this feature is still there, and it should be.
your 11x zero is the DMSS protocol and the software 0002-0103 has the stik mode feature
The 11x-DSM is a different protocol and the software 0002-0103 is the modified firmware where the stik mode feature was removed.
JR Japan says emphatically the Japanese software is not compatible with the Spektrum software.
that is the reason after my upgrade to 0002-0103 the stik mode is not there. happy flying and loads of good luck.
