DX7 and AR6110e
I'm a newbie to Spectrum radios and electric powered. I have set up a delta wing with my DX7 and AR6110e receiver. Everything works fine, except that the throttle stick has to be 50% of the way up before the motor turns on. So where did I go wrong?
Assuming the Monitor shows end-to-end travel, put a servo on in place of the ESC. Does it move with the throttle stick from end to end? If not, then your receiver is bad - and as Zeeb pointed out, unless you bought it 10 years ago, it's a fake.
If the servo does move correctly, then the problem is your ESC. It needs to be calibrated to work with your system. What ESC is it? Got a link to the manual?
Andy
