Turn off Start/Stop sound for timer on JR T44
My Feedback: (13)
NY
Does anyone know how to turn off the Start/Stop sound for the timer when the throttle stick is used as the SPS?
In the TX Settings I only found the sound for "Timer" which would turn the Start/Stop and Timer End sounds off.
The start/stop beeps come from the timer; they are not a part of the stick position switches setup. If you want the timer to have count down beeps, you have to put up with the start/stop beeps. You can less the frequency of the start/stop beeps if you set the SPS threshold as low as possible by setting the bar chart points to OFF - ON - ON. Set one of the values for the LOW range to 100 and INH the other values.
Or, don’t use the SPS to activate the timer. Use something else, such as the F button by the edge of the display. If you have a throttle cut, use the switch for that to activate the timer.
My Feedback: (13)
NY
Thank you for your reply AWorrest! This was cross posted and what I ended up doing was to set the start on SPS for throttle at 25% (might move that to 50%) and turn off with throttle cut. For the longest time I didn't even notice the start/stop sound happening on my DX7 until someone pointed out that I could turn it off. Since then I just got used to not having to hear it, something I'm sure I would have gotten used to again if need be.
