8611 Servos?
My Feedback: (17)
TX
8611 Servos?
Where can I get a single 8611 or several for my new Carden Edge that I'm building. I need one atleast to help in building my servo pockets exact. I could even use an empty case for one. I don't care if it doesn't even work. I just need one to help in building. Thanks for any info you might be able to give.
RE: 8611 Servos?
The 8611 is difficult to come by right now, we do not have any available at this time. Dimmensions on the 8611 can be found herre, http://horizon.hobbyshopnow.com/prod...?prod=JRPS8611 . It is about 2mm larger in every direction than the 8411. In most cases, unless the servo pocket is a tight fit on an 8411, the 8611 will drop in without any modifications.
RE: 8611 Servos?
There was a recent shipment, but all of that shipment is gone. There are more expected early to mid next month subject to change. You may receive them soon, but it is difficult to determine at this point. Contact your dealer to see if he receives them in the next week or 2. If not, it may be some time in January.
