JR Radio & Spektrum Radios Discuss all your JR and Spektrum gear.
Xf 421 Ex
Old 07-12-2002, 12:08 AM
DavidAgar
My Feedback: (108)
DavidAgar's Avatar
Default Xf 421 Ex
I recently picked one of these radios up here on RCU. The radio is reported to be about 10 months old or in the ball park. While cleaning the radio I noticed that the battery cover was a jar, so I removed it to reposition it and install it again. In looking at the battery I noticed that it had a 9 volt type connector going to the battery that was just about to fall off. I removed the battery and in looking inside the transmitter I could see that the wires had been pinched and that the bare copper was showing. I removed the transmitter back and to my surprize I found a small board that appears to have been installed in the radio with a 2 pin type bracket to plug in the battery, that was just kinda floating around in the transmitter. My question would be, is this 9 volt style plug the way it is supposed to be? I looked into my other JR and it does have this type of battery. I have velcroed this board to the inside of the case and replaced the frayed 9 volt plug. Any help would be greatly appreciated. Thanks Dave
Old 07-12-2002, 12:23 AM
Buz^
Default Hi Dave
Are you saying that while you were showing off with my plane, doing a touch & go off a bail of hay at the flying field (true story guy's) we could have also had a radio failure?HEHEHE Buzz THE PICTURE SHOW'S CLEARLY, DAVE IS WAITING FOR THE GRASS HAY TO BE BAILED BEFORE TAKE-OFF.
Old 07-12-2002, 05:01 PM
dsnyder
dsnyder's Avatar
Default Xf 421 Ex
The 421 comes with a small black plug for the battery. It doesn't come with a 9 volt type connector.
