Wrong Crystal?
In April I sent in a 940 and a 945 receiver to be tuned specifically to my 10X transmitter module on channel 15. Last week, while using the 940 on a turbine test bench, my local RAM rep noticed that it had a gray colored crystal in it and said he didn't know how the receiver was working since it is a dual conversion receiver and the gray crystals are for single conversion receivers. Sure enough, when I got home I checked the 945 which is mounted in a JMP T-33, it has a red one which I understand is the correct one.
If the gray one is a single conversion crystal, why would Horizon return that receiver with the wrong crystal and, more to the point, how can they do the requested fine tuning with a single conversion crystal in a dual conversion receiver?
Could you please give us a call so we can research the specific repair, find out who did the repair, and find any repair notes we may have to investigate how this happend. This way we can be sure it does not happen again. If you can, please give our product support department a call toll free at 877-504-0233 at your convience.
