9302 Trim Offset
NV
9302 Trim Offset
Hi Danny,
Need a little help. Is there a trim offset method on the 9303? I've been through the manual about a hundred times now and can't seem to find it. But... That doesn't mean it's not there.
RE: 9302 Trim Offset
Trim offset is a function in mechanical trim radios. The 9303 is digital trim system and the trim offset function is not needed since the trims are automatically stored for every model.
The original 8103 was an all analogue trim. The 8103 ADT is just an upgrade but still maintains one analogue trim.. I believe the S/W stayed the same.
[8D]
[8D]
Sorry, correction to my last. There was a minor SW change in the 8103 ( refer to ADT addendum IV.1 ) and I quote :
" IV. X3810 ADT Digital trim Software Updates: Air and Glider.
1) Trim Offset Function : Function Mode
Please note that since the new Digital Trim levers automatically store the desired Aileron, Elevator and Rudder trim values for each model, the Trim offset function is no longer required."
[8D]
[8D]
